Budget M42 turbo build
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    #106
    Originally posted by TooTall90
    good work so far, i cant wait to see more progress!
    anyone ever retrofit the e36 coil pack into an e30? i think it would really clean up the engine bay. is it even possible? im talking about #1 in this image.
    Why on earth would you want to do that??? Do the coil-on-plug conversion, much much better.
    • Schnitzer318is
      • Jan 2008
      • 2057
      #107
      Can't run the M42 cover though... ;)
      Seriously... that's the only reason I haven't gone COP yet. Want to so bad, but the motors just look like ass without the cover there. JMO though... others may think it looks great. Too fuhraze for me though.
      "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
      91 318is Turbo Sold
      87 325 Daily driver Sold
      06 4.8is X5
      06 Mtec X3
      05 4.4i X5 Sold
      92 325ic Sold & Re-purchased
      90 325i Sold
      97 328is Sold
      01 323ci Sold
      92 325i Sold
      83 528e Totaled
      98 328i Sold
      93 325i Sold
      • TooTall90
        • 338
        #108
        exactly.
        Strategic Alpine Command:...sig loading
        • CorvallisBMW
          • 13039
          #109
          then make a custom cover. Besides it it's done right, it looks totally stock and factory.
          • gearheadE30
            • Jun 2007
            • 3734
            #110
            I'll be going COP eventually fwiw, but right now I'm getting up there in the budget and that $200 can go elsewhere right now. That's an easy thing to do later, and even without the cover, if you do it right, it looks pretty good.
            btw I'll be gone for about the next week, but I did get the stock exhaust and header out and am mocking everything up right now. Next time the car runs, it will have a turbo :)
            Project M42 Turbo
            • Dj Buttchug
              • Jun 2010
              • 7678
              #111
              I think it looks cool when the cover is off and the coils show.
              Turbo M42 Build Thread :Here
              Ig:ryno_pzk
              I like the tuna here.
              Originally posted by lambo
              • e304me
                • Feb 2006
                • 1374
                #112
                the cop can look good:
                • gearheadE30
                  • Jun 2007
                  • 3734
                  #113
                  all unnecessary brackets on the passenger side of the engine bay have been removed and I cut off the wastegate port on the manifold because it would force me to delete AC. Time for lunch, then pull AC lines temporarily and start mocking everything up. So far, so good...
                  Project M42 Turbo
                  • Dj Buttchug
                    • Jun 2010
                    • 7678
                    #114
                    i have a stupid question. How did you get the exhaust housing off of your turbo?
                    I need to reclock mine but I cant get mine off. Not sure what turbo your running but Im using a garrett gt2871r
                    Ig:ryno_pzk
                    • e30m3s54turbo
                      • Jun 2010
                      • 3281
                      #115
                      Nice project.
                      • e30guydownunder
                        • Jul 2008
                        • 874
                        #116
                        There should be about 6 bolts screwed into the turbine housine from the centre side. there will be some half moon plates between each pair of bolts, this is the clamp. Loosen all of these and once you crack any bond (the turbine might have temporarily stuck to the centre, a light tap with a rubber hammer should free it) the turbine housing should be able to rotate in relation to the centre.
                        Same deal for the compressor housing.
                        You got a project thread? 2871 sounds interesting and is where I would plan to go if I'm not happy with the results I get.
                        - Chris
                        Project M42 - 255 @ 19 psi
                        • Schnitzer318is
                          • Jan 2008
                          • 2057
                          #117
                          Sweet... you'll never go back to non turbo.
                          Still need to get the pics of my gauges. Also just added a hallman manual boost controller. MUCH better than my previous controller. No more boost leak past 4500rpms... 11psi all the way to redline!
                          91 318is Turbo Sold
                          06 4.8is X5
                          06 Mtec X3
                          05 4.4i X5 Sold
                          90 325i Sold
                          97 328is Sold
                          01 323ci Sold
                          92 325i Sold
                          83 528e Totaled
                          98 328i Sold
                          93 325i Sold
                          • Dj Buttchug
                            • Jun 2010
                            • 7678
                            #118
                            A hard wack with a rubber mallet did the trick!! I was afraid to beat the shit out of it but it worked out well.
                            No build thread yet. Im waitiing until I finish the build. I went with a 2871 because its perfect for m42 displacement. Its also common on sr20det.
                            spools around 3k and is capable of 18 or so psi
                            Ig:ryno_pzk
                            • Schnitzer318is
                              • Jan 2008
                              • 2057
                              #119
                              Here's what I ended up with for my gauges. I like this much better than the setup I had before. Also installed a Hallman Pro boost controller. No more boost bleed/leak for the win. I recommend one if you don't have something else lined up already.
                              91 318is Turbo Sold
                              06 4.8is X5
                              06 Mtec X3
                              05 4.4i X5 Sold
                              90 325i Sold
                              97 328is Sold
                              01 323ci Sold
                              92 325i Sold
                              83 528e Totaled
                              98 328i Sold
                              93 325i Sold
                              • gearheadE30
                                • Jun 2007
                                • 3734
                                #120
                                That looks really nice, but I want to keep that storage area. Still trying to decide what to do there....
                                Also, with a good chunk of luck, I *might* be able to get the car running tomorrow. I got the manifold back from the shop today and now the downpipe and everything else fits, new bolts and gasket for the turbo, manifold studs, oil pressure limiter, and a few other odds and ends. The 9006 HID bulbs for the ellipsoids also showed up so I'm not blinding people with teh HID H4s. I'll post pics comparing the cutoffs once I get it all installed.
                                BTW for boost control I'm using a Tial 38mm wastegate with a 7.5psi spring for now. Once the tune is good, I already have a 10psi spring waiting :)
                                Project M42 Turbo
