Absolutely phenomenal - world class work. In for engine plans/pics. ITBs...
Meet the bastard child.
HOWTOs:
DB vert plastic bumpers
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
e30m3s54turbo: I save my money for tuner parts. -
Bump.
I wanna see some pics of the cluster in the car if you've got them Tony.
RTFM:http://www.r3vlimited.com/board/showthread.php?t=56950Comment
I just finished reading the whole thread... Amazing work!1988 325is imolarotII/ plastic bumper swap/ e36 m3-z3 2.8 5 lug swap/ e36 m3 bilsteins/ e36 m3 h&r race spring up front/ GC rear coilover / 21mm vert sway bar/ m3 offset bushing/ OEM bushings/ S3.73 rear end/ full black interior/ e46 sport seats/ BBS style 5
Instagram - AnthonyVzzComment
Managed to get out and make a start on this. First thing to do is reconfigure the car from an auto to a manual. Did this while it was still sitting in the car, which was easy enough, at least it seems that way, I've no idea what they actually do ha.
Upshot is that the DME no longer looks for the trans comp and wont send any error messages to the cluster. There is apparently also a software update to give us the correct file for the manual (apparently a slightly different tune/idle control) but we couldn't load it as the DME relates to a 840i not the 540i and they didn't have the correct software and so the DME wouldn't accept it. As I understand it anyway. So to start with we'll be wiring it to neutral. Will make very little difference to the way it runs anyway.
Geeks at work.
Turns out this early girl from 2/96 is an oddball assortment of leftovers from previous models. Still has EWS 2, as mentioned a DME from an E31, analogue signals from the tach and coolant sensor and a distinct lack of CANBUS, of which only the DME and the EGS (trans comp) are connected on.
With the later E46 systems the E30 is running on, this means I'm looking at having to incorporate the older style EWS and most likely the older KOMBI cluster too as the current one is entirely digital/run from BUS.
A later donor car probably would have, more or less, plugged straight in but oh well...sigpicComment
After all the E46 swap work you're going to drop in an M62?!?!?! Please proceed, you do quality work.
I suppose you'd be able to recoup a lot of your investment in selling the old engine and parting the E39. Not to mention you already have so much time and money tied up in the E30 chassis to start over with a different car. God, how I envy you.Comment
Yours for $12.7K USD http://www.trademe.co.nz/Browse/List...x?id=738525654
What sort of number do you think it would sell at
