Vorshlag $2010 GRM Challenge car - BMW E30 V8
    Project Update for Sept 27, 2010: What a difference a week makes...
    One week ago we had one flare finished, and the car didn't run or stop, and it looked like total crap. Now we've got all 4 flares completed and the bodywork "done" and the car "painted". Now its less craplike. We took huge shortcuts, as you will likely notice. Some of the bodywork is visible under the flat black primer, and the roof likes like a mess. The bottlecaps were just for painting, so ignore those, too.
    Friday night was an all-nighter, and Saturday and Sunday were also insanely work days. I lost count of how many people were there. We've worked until midnight or later for so many days in a row I didn't even know what day it was - I had to look it up. We had planned to and paid for an autocross on Sunday in the E30, to test all sorts of things, but missed the paint and bodywork plan by a mile. Let's see what I can remember...
    The old E36 K-brand struts we bought for $15 were partially revived (one needed fluid) and turned into coilovers. Costas had fun with the plasma cutter chopping off the old lower perches, and Paul M cleaned up the used coilover adapters these came with on the lathe, for a better fit. They are on the car but we have yet to test them on the road or set ride height. There's some old crusty Eibach springs on the front that came with my '97 M3 when it had TCK struts. They've been on the car for years and sitting on the shelf for longer. 750 #/in and I hope that works. No time to test!
    Chris, our wiring fiend, finished the custom E36 ABS wiring harness over Friday and Saturday and ran some old CAT5 for the sensor wiring. Chris and Costas did some testing Friday night in the rain on my wife's E36 M3 and figured out how the pedal position sensor works, and we're adapting it to be a "tunable" ABS. Its pretty complex, and involves expensive items like some painters tape. I'll explain further, if it works. Heh.
    Chris was dodging sparks from my welding on the bottoms of the flares the whole time. I think I only barely caught him on fire. I was adding reinforcement plates to the bottom sections to make the box flares more rigid and "cone hit capable".
    Chris and Costas got the new harness routed through the dash and car and mounted the ABS computer as well as the truck ECU in the glove box. It looks cleaner than the pics here show.
    I started out Friday by cutting the top left flare off and fixing a lot of bends and angle problems. After taking some time checking angles I found the problem, made a little patch panel to bridge the gap from the flare top to the fender, and got it all welded back together and the underside brackets built and welded in place. The right front fender had similar problems, as the hammer formed top was made from the same (incorrectly cut) pattern, so that was some extra fun there, too. Somewhere in there McCall and I made rear bumper brackets (very light, also made from electrical conduit and scrap sheet). So the rear bumper was mounted and attached to the flares at the leading edges. Lined up pretty well (better than the front) but with so many pics in this update I didn't show it.
    Paul M and Jason helped me cut and hold and hammer these front flares into shape. I don't know how many hours I spent welding on these but it was a lot. Probably 20 hours just from this weekend alone was spent on the front flares. We did a lot of spot welding and hammer/dolly work fixes to the rears before bodywork began, too. Making custom steel box flares is a LOT of freagin work. Trust me on that one. We have probably 60-80 hours in the layout, cutting, fab work, grinding, and bodywork on these flares. And they are far from perfect - we were pretty rushed on the front pair. 4 people worked on them over the course of the last 2 weeks. That 60-80 hour number might be low, too. It didn't help that we'd never made anything like these, of course.
    We had a volunteer that knows paint and body pretty well help us this weekend on the bodywork and some of the spraying. He didn't want to be named so we'll call him The Underpants Gnome. TUG did the mud work on the rear flares, hood and trunk for about 8 hours on Saturday and told us we were insane to think we'd be autocrossing the next day. He got the rears shot with primer after that full day of bodywork, and said he needed another week to get the bodywork right. The roof, doors, and front fenders were not touched yet. We had another full day. Hmm...
    So Saturday night we decided to punt and pound out what we could on Sunday. "Right" was far from our goal. We needed "good enough at 50 mph". Jason, Matt, Amy and I poured another 12 hours on Sunday and mudded/shaped/sanded the front fenders and roof "quick and dirty", and just ran the D.A. over the doors quick and got to taping and cleaning. We poured in an entire day of bodywork, sanding and prep - done by people that had little to no skills in this area. We're racers, not bodymen!
    We got it looking good enough from 50 feet, so we degreased the body and trunk and rolled it outside. Even with heavy winds gusting to 25 mph Jason sprayed a coat of sandable primer (mostly) on the car and all of the panels by 5 pm Sunday, while Matt, Amy and I held up a 20' x 10' tarp to block the wind. We don't have a paint booth, you know?? The winds were knocking us over holding this huge sail, but it deflected some of the wind away from the spray gun.
    We ran to grab food at 6 pm and were back sanding this now dried primer coat by 7:30. We had it sanded, cleaned and ready to shoot by 8 pm, when TUG shot some black primer on the whole car and we were done by 9 pm. We were all ready to collapse but we got it sprayed. Always bet on black!
    This morning I went out early and pulled the paper and tape off the car and panels. We'll put it together tonight and try to get some sort of testing done tomorrow. Probably something illegal and insanely dangerous. We pack up the trailer Wednesday to go 17 hours to Gainesville, Florida for the $2010 GRM Challenge. We might be wrenching in the trailer on the way. Its OK - it has lights inside... Costas, McCall, Matt and I will be there with the E30, one way or another. It will likely have zero testing, and might explode into a huge fireball, but we're going to be there and make loud noises.
    Bleary eyed. I'm going to crawl under my desk and take a much needed nap. More soon...
    Terry Fair - www.vorshlag.com
    Project Thread for the now-burned-to-a-crisp $2011 GRM Challenge Winning E30 V8 :(
      Good luck with the GRM Challenge. I was wondering why you guys ended up not making it to the autocross yesterday, now I see why!
        Good luck to all the guys from the Vorshlag team. Go get those other E30 guys :D
        - Chris
        Project M42 - 255 @ 19 psi
          Update for Sept 28, 2010: Normally I'd wait more than a day to post another update, but the differences from the last 24 hours are dramatic:
          KA-POW!
          We spent all night putting the car body panels and interior back together and it looks good. We've also started on the graphic layout, with the decals being cut today on one of the team's plotters. Hopefully we're putting decals on tonight or tomorrow before we load up... otherwise Costas will be laying them down at 70 mph inside the trailer. "It won't be the first time, nor the last". :D
          We had Amy, me, Paul Costas and Paul M (aka: The Two Pauls) working from about 6 pm until well after midnight but the results were worth the additional late night push. I painted the bumpers flat black; I started by cleaning the E36 front and rear bumper covers, then hitting them with Scotchbrite pads to scuff the surfaces (they were both used pieces that were gloss black, but pretty beat up). Cleaned the CCWs while I was at it, plus a bunch of other pieces we painted last night: rear window trim, wiper motor cover plate, and some other bits and pieces.
          Amy and Paul M cleaned up the various OEM weatherstrip seals (Armor All) and installed them for the hood, trunk, both door openings and rear window surrounds. We also started laying out where decals would go, and I took a ton of measurements for our upcoming graphics (pretty simple - mostly just big Vorshlag decals). The Two Pauls then installed the front and rear window glass - which neither had done before. They did a good job - no cracks!
          The engine bay is a mess. Its nowhere NEAR my normal engine cleanliness standards of even the lamest cars I've ever owned. I usually get them crazy clean, detailed to perfection, and am proud to open the hood on any vehicle I own and show it off. Except this E30. :( We just flat ran out of time and cannot do the proper "pull the engine, bodywork the panels, repaint and reassemble" that we had planned. I had it pretty damn clean right after I bought the car last year, but we cut away several brackets we didn't need and then sanded/primed the areas... and now there's ugly gray primer in an otherwise shiny blue engine bay. Oiy.
          Amy looked at it and decided that the worst part was the wiper cover. Its normally covered in ugly studs and sound insulation mat, which we cut off and ground smooth months ago. It was now rusty bare metal and looked terrible, so she yanked it out, Paul M prepped the surface with the Crud Buster, I blasted it with flat black, Amy laid on a small Vorshlag decal (over some crazy surface shapes) and then she reinstalled it. Huge difference. I'll clean the engine bay tonight and we'll go with the "look at the V8 and ignore the rest" for the underhood area. She also helped with the interior trim pieces - door sill, etc. - and cleaned and polished all of the glass. The Two Pauls reinstalled the carpet and cut around the 4-point bar. It looks pretty good in there now. We got the rear deck lid, dash panel, and center console cleaned up but still need to detail the door panels and maybe find a piece of carpet to cover the area for the missing backseat.
          Costas has decal experience and had a strip of black vinyl he wanted to use for the windshield. He and Amy laid that on at a 6" height and we'll slap a yellow decal over that when they are cut today. We can all see underneath this windshield top strip well enough and it will provide good shade for racing under bright skies. Paul M also got the rear Dzus fasteners riveted to the trunk panel again.
          The Two Pauls hung the doors, and that took a while. Blue tape on the leading edges to avoid scratches, the limit strap fell inside the door so the door panel had to come off one side, etc. Fun fun fun! Paul M laid on some black electrical tape for the X's over the headlight bulbs, for that period correct look.
          I rolled the car out this morning and snapped some pictures as the sun was coming up...
          We are all quite surprised how good it looks, even in black primer, for as rushed as the bodywork has been. Its far from perfect, but its mean and looks like it can get the job done. I found some stick-on chrome letters at an auto parts store and put those on for a little description of the model (325e became VM-353) and to sport our $2010 roots. Represent!
          Some last bits still need to go on the car (rear quarter windows, kick panels), some wiring bits need to be finished (ABS light, a ground or two) and some pieces need to be found in the shop and installed (hood pins, one more front bumper trim piece). We have got to mount the 15x10" wheels and do some driving on them, too. Then the decals go on and we load it on the trailer tomorrow. If all goes well. :)
          More soon!
            Looks good guys, See you on thursday evening at the host hotel.
            FS:///M-Tech Wallets.
            http://www.r3vlimited.com/board/showthread.php?t=224601
              Wow this turned out awesome! Good work!
                looks awesome terry. can't wait to see what this thing does on track.
                '12 F30 328i Sport Line
                '91 SpecE30 #523
                '00 Ford F-350 Dually Tow Vehicle
                BMWCCA #360858 NASA #
                128290
                  Looking forward to meeting you guys in person and seeing this beast :D
                  john@m20guru.com
                  Links:
                    Its pretty awesome that this could be done for $2010 though i'll throw in the stipulation that no ordinary person without the resources/shop could have done it.
                    I hope that as my car progresses it'll eventually run with ya'll. just an amazing project and great thread. I love reading this kind of stuff and just wish i had the means to learn the fabrication side of things more rather than being stuck behind the computer on the design side :(
                      Actually there's 50+ cars every year that do it at the Challenge, almost none have shops.
                      I just picked up a car for next year, but it's no e30 lol, got it before it went on the wrecker, gave the owner $100
                      john@m20guru.com
                      Links:
                        Yea i know, but I know most of those guys have some pretty impressive garage shops and capabilities.
                          Its all good - just get a lot of friends with some skills, somebody with a lot of tools, and dig in! We burned 1500+ hours of after hours and volunteer time over the last 12 months to get this far.... and that was still FAR short of what the car needed to be competitive. We were semi-quick in the autocross (with zero testing and the wrong alignment and spring rates I think we were 7th fastest? Still don't know for sure!) but our drag times... well, we broke a halfshaft on the first run, fixed that, then 3rd gear exploded. GRR!
                          I'll post up an update later with more info (3 updates actually). We had a blast, and we'll (probably) be back next year. VENGEANCE WILL BE OURS! :razz:
                            The car looked really quick at the auto-x, even cooler that it was sideways almost the entire time. :)
                            Sucks about the tranny.. I was really interested to see what it could do. But Im excited to see you guys are coming back next year!
                            -Jay
                            -Jay
                            2014 NASA FL se30 champ #81
                            2001 se46 3 year plan in progress
                              Where did you guys stay? We missed you at the banquets and awards ceremonies at the host hotel (food and more importantly BEER was included in your ticket price).
                              You guys actually did well, as you saw with the "other e30" and the Lexus powered Miata, it takes a few years to get this event down.
                              john@m20guru.com
                              Links:
                                really looking forward to seeing you guys out there next year!
                                xoxo - WreckRacing
