After a year of searching, an Alpineweiß story
  • iwantspeed
    • 3164
    #691
    So my Akg shifter arrived Monday.
    I immediately installed it after work.
    Everything fit nicely it shifts great
    Upshifts and down shifts part throttle and full throttle are just so easy.
    Project
    Parts for Sale
    Feedback
    YouTube Channel
    • Sh3rpak!ng
      • Jan 2014
      • 2667
      #692
      Sick! I got excited for you when I saw those pictures. how's the "shifter play" now?
      Shadetree30
      • iwantspeed
        • 3164
        #693
        Very little.
        There is room for one more shim I between the DSSR and the Akg product.
        Project
        Parts for Sale
        Feedback
        YouTube Channel
        • Aufbau Principle
          • Jan 2013
          • 121
          #694
          What transmission bushings are you running? How's the vibration?
          • iwantspeed
            • 3164
            #695
            engine and transmission mounts are
            condor speed shop UHMW solid delrin mounts
            it vibrates a lot and is loud.
            lots of squeaks and rattles because of this too.
            Project
            Parts for Sale
            Feedback
            YouTube Channel
            • iwantspeed
              • 3164
              #696
              New additions to the garage
              Project
              Parts for Sale
              Feedback
              YouTube Channel
              • iwantspeed
                • 3164
                #697
                Natalie is getting some upgrades.
                -RHD 7lb lightweight flywheel
                -Sachs Clutch disc
                -Sachs pressure plate
                -Fag pilot bearing
                -Sachs euro 323 e30 throwout bearing
                -clutch pivot fork
                -upgraded brass pivot pin
                -pivot fork spring
                -Fte clutch master cylinder
                -Fte salve master cylinder
                -45 degree fitting for master cylinder
                -BMW flywheel bolts
                -BMW pressure plate bolts
                It's going to be a fun weekend.
                Project
                Parts for Sale
                Feedback
                YouTube Channel
                • 2mAn
                  Señior Mod
                  • 21053
                  #698
                  I want one of those AKG shifters so badly!
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  Make R3V Great Again -2020
                  • iwantspeed
                    • 3164
                    #699
                    Get one its awesome
                    Project
                    Parts for Sale
                    Feedback
                    YouTube Channel
                    • iwantspeed
                      • 3164
                      #700
                      hey guys got the clutch hydraulics replaced
                      clutch master and hardline
                      clutch slave with UUC hardline
                      bleeding the clutch by your self sucks but can be done.
                      dropped the exhaust,
                      and got better pictures of the inner lap belt mount clearance to the center support bearing
                      new shop dog!
                      bought an awesome cool tool
                      harbor freight transmission jack
                      have to get creative when trying to undue the starter nuts
                      clamped the tool to the master
                      so everyone complains about the top trans bolt
                      i placed a floor jack under the front subframe and removed the subframe bolts.
                      inserted head bolts and lowered the entire front drive-train as one unit a few inches
                      this allows adequate room to access the top bolts.
                      getting ready to drop the front end
                      last bolt
                      was able to separate it. woot
                      old parts
                      trans jack coming in handy
                      pressure plate and clutch disc removed
                      made a custom tool to remove the flywheel bolts
                      i rented a tool from my local pepboys
                      slide hammer and pilot bearing puller
                      it was way to big to fit inside of the bearing
                      i found a rod to fit inside to keep the jaw from popping out and it worked
                      tool configuration
                      new flywheel ready to go on.
                      new pilot bearing installed
                      new flywheel going on.
                      locking tool in place
                      clutch disc installed
                      thanks to mike for letting me borrow the clutch alignment tool.(buttjuice)
                      pressure plate installed
                      plastic pivot pin was broken
                      bell housing cleaned up and brass pivot pin installed
                      old flywheel weight 20 lbs new flywheel 7 lbs.
                      winning
                      Project
                      Parts for Sale
                      Feedback
                      YouTube Channel
                      • iwantspeed
                        • 3164
                        #701
                        some garage updates
                        I cutoff of the prebuilt shelf off the wall and lowered it to work bench height.
                        i also added a pegboard wall.
                        I borrowed my wife's car and it barely fit.
                        I have gotten some filing cabinets for free.
                        great for storing car parts, cleaning supplies, and paint cans.
                        but it doesnt match.
                        I took the drawers out, removed the handles, and the lock tumbler.
                        I'm going for a craftsman look. gloss red exterior black drawers silver handles
                        first file cabinet done.
                        started working on the other ones.
                        couldnt get the drawer out.
                        so i just masked everything to paint it black.
                        all done.
                        im happy with the results so I will do the engine stand next.
                        Project
                        Parts for Sale
                        Feedback
                        YouTube Channel
                        • iwantspeed
                          • 3164
                          #702
                          Hey guys I was having some running issues in my e30.
                          I ohm tested the coolant temp switch and it was out of spec.
                          That was replaced
                          The problem continued
                          The crank position sensor was out of spec also so that was replaced
                          Problem continued and the ignition coil was out of spec. I borrowed one from a friends shop and what do you know fixed!
                          It had a code 1222 and code 1261
                          I did a smoke test and it had minimal vaccum leaks.
                          My friend Tyler apex goblin helping me smoke test. It really is a 2 person job.
                          Problem 100% was a bad ignition coil and the one on the car was approximately 5 years old.
                          I have a new set of plugs to install soon too.
                          Project
                          Parts for Sale
                          Feedback
                          YouTube Channel
                          • jeenyus
                            • Aug 2011
                            • 2064
                            #703
                            great progress. how does the new flywheel feel? made it passed break-in period yet?
                            • iwantspeed
                              • 3164
                              #704
                              thanks
                              break in period has passed.
                              i have done lots of wide open throttle up through the gears and its great
                              i highly recommend it. let me know if you are interested in buying one i have one on the shelf.
                              Project
                              Parts for Sale
                              Feedback
                              YouTube Channel
                              • iwantspeed
                                • 3164
                                #705
                                I lost my is lip thanks to a big rig that had lost a tire.
                                Ran over the tire carcass and ripped of my is lip and Ryan g splitter. :hitler:
                                Thanks to Matt at Garagistic he had one brand new in stock.
                                Couple of coats of SEM trim paint and back in business.
                                Project
                                Parts for Sale
                                Feedback
                                YouTube Channel
