After a year of searching, an Alpineweiß story
  • 2mAn
    Señior Mod
    • 21053
    #676
    I have a similar idea for plates for my car, but it wont be GTS and wont be the black legaacy ones. Glad you got the ones you want though!
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
    • TeXJ
      • 1914
      #677
      Great update!
      1990 325is
      m52b28
      3.73lsd
      g260 (1987 325is 5spd tranny)
      • Sh3rpak!ng
        • Jan 2014
        • 2667
        #678
        Nice update!! I love those plates.
        YES thank you for posting pictures of some radiator brackets. I have been trying to devise a better/cleaner design in my head than the OEM plastic bracket (mine is so beat) for ages and the answer was staring me in the face the whole time... just use the e36 mounting points! Awesome! I'll be doing that soon.
        I'm surprised you've had so much trouble with the aux fan switch leaking. I've never had an issue between 2 oem e36 radiators, a mishimoto aluminum radiator like yours, an aluminum koyorad, and a couple different switches. I think I even reused the sealing washer half the time
        Shadetree30
        • iwantspeed
          • 3164
          #679
          Originally posted by pcrbmw
          Those vintage plates are wicked awesome! I hope we eventually get legacy plates like that in Jersey...
          Your e30 looks great!
          thanks it took along time to get them but worth the wait
          ya super excited about these plates
          Originally posted by TeXJ
          Great update!
          thanks
          thanks love the plates
          I had to try a few ideas before finding one that stopped leaking.
          i started working on a new mount on Friday.
          Project
          Parts for Sale
          Feedback
          YouTube Channel
          • iwantspeed
            • 3164
            #680
            Old radiator bracket
            New bracket. I made it out of 7075 t6 aluminum.
            I machined it and tapped it. I used two existing holes in the core support to mount it.
            Project
            Parts for Sale
            Feedback
            YouTube Channel
            • iwantspeed
              • 3164
              #681
              I got a set of s50/m50 green top 17lb injectors for free.
              Only thing wrong with them was one missing pintle cap.
              Thanks chub tone
              I contacted Dimitry owner of Mepeh injection, he was very polite I met him at his house to pick up a rebuild kit for my injectors. He offered to install my injectors on his machine to flow match them and test them out.
              We ran them at 3 bar at 7k rpm
              and up to 4 bar and 7k rpm they passed all the test.
              Also ran a draining cycle and they all where very close to one another.
              Cutting the pintle caps off
              Old injector filters vs new high flow filters.
              Injectors completely disassembled and cleaned.
              Rebuild kit plus a few spares not in the picture.
              6 high flow filters
              6 upper O rings
              6 spacers
              6 lower O rings
              6 pintle caps
              Filter extraction tool not in the picture
              Assembled just need to put some Vaseline on the o rings
              Installed with a new 3.0 bar fuel pressure regulator
              Installed
              Unplug negative battery terminal for 30
              Minutes and it will help the ecu clear out and help calibrate to the new injectors on the first test drive.
              Project
              Parts for Sale
              Feedback
              YouTube Channel
              • iwantspeed
                • 3164
                #682
                I documented some of the injector rebuild process for those interested.
                3 short clips but it may help someone tackle this job.
                Step 1
                Step 2
                Step 3
                Project
                Parts for Sale
                Feedback
                YouTube Channel
                • iwantspeed
                  • 3164
                  #683
                  After installing the new injectors the car had a check engine light come on.
                  Code 1262
                  Fuel pump Relay control......
                  Before diving deep into testing I decided to replace the fuel pump relay and the main relay. Easier said then done.
                  A few years back I did an engine bay wire tuck.
                  This involves removing the engine harness completely and shortening and relocating things.
                  The relays used to be on a bracket near the afm they are now inside the m3 harness cover.
                  I tried researching what part number relay to order but was struggling to
                  Verify what to order.
                  Old main relay
                  Old fuel pump relay
                  With the help from my parts guy and Google we figured what to get.
                  Part number for a white main relay from BMW.
                  For a 1989 325i build date 12/1988
                  173 DME
                  motronic 1.3
                  Part number for a fuel pump relay
                  Same part number will be correct for the o2 sensor heater relay
                  Stoaked new relays.
                  Didn't buy the relay for the o2 sensor because they were out of stock.
                  Test drive was a great success no more cutting out and check engine lights.
                  Project
                  Parts for Sale
                  Feedback
                  YouTube Channel
                  • iwantspeed
                    • 3164
                    #684
                    very excited i have an e30 akg stage 2 shifter on the way!!!
                    (just a high res sample pic)
                    Project
                    Parts for Sale
                    Feedback
                    YouTube Channel
                    • pandaboo911
                      • 2070
                      #685
                      Sweet! Put a rubber ring under the mount :P
                      • efficient
                        • Feb 2012
                        • 3312
                        #686
                        I have a question what did you soak the valve cover gasket with?
                        • iwantspeed
                          • 3164
                          #687
                          you can buy it here
                          Henkel 37558 LOCTITE® Aviation Form-A-Gasket - 16 oz Brush-Top Can - Visit and view our entire SkyGeek, Shop Supplies, Aerospace Sealants, Gasket Sealant, Henkel LOCTITE® Aviation Gasket Sealant, section at SkyGeek!
                          Project
                          Parts for Sale
                          Feedback
                          YouTube Channel
                          • iwantspeed
                            • 3164
                            #688
                            thanks for the tip will do
                            Project
                            Parts for Sale
                            Feedback
                            YouTube Channel
                            • jeenyus
                              • Aug 2011
                              • 2064
                              #689
                              took me a couple days, but I got through this finally. Great progress. It's amazing how many things still need to be fixed on a "clean e30" like what you originally were looking for. Well done mate.
                              Also pretty awesome how often you seem to get shit for free or whatever. Sounds like a great setup.
                              • iwantspeed
                                • 3164
                                #690
                                Thanks for reading.
                                I just try to help people out and sometimes they return the favor with free stuff.
                                Project
                                Parts for Sale
                                Feedback
                                YouTube Channel
