Reap3rs E30 Bought back, Now M52B28
  • Reap3r
    • 596
    #226
    Originally posted by bergie_318is
    sucks about your work bro, hopefully it all picks up again soon! ps harrys thurs?
    Yeah I'm hoping it does too, I should be at harrys tomorrow man. Will send ya a txt tomorrow arvo.
    Turbo M42 Build thread:
    http://www.r3vlimited.com/board/showthread.php?t=169672
    • e30guydownunder
      • Jul 2008
      • 874
      #227
      while your busy working on your turbo M42....this is what your msissing:
      - Chris
      Project M42 - 255 @ 19 psi
      • Reap3r
        • 596
        #228
        I Worked on the car for a couple of hours this morning, Got the remote filter housing & oil cooler in along with all the gauges hooked up & functioning. Now its just a case of cleaning things up & running a few more wires here & there. Also have to make some Alternator bracket spacing. The way the oil cooler is may not be the best, but it was the most efficient way to do it with covering the least amount of intercooler with the amount of lines I had to run to it.
        Anyway heres a couple of pics.
        • e30guydownunder
          • Jul 2008
          • 874
          #229
          ohh shit, I wondered why I still had blocks of alloy that looked like alternator spacers! If you want I can mail you them? pm me your address.
          But nice progress so far, looking pretty good
          - Chris
          • Reap3r
            • 596
            #230
            I'll let you know by monday man, Going to look into making my own tomorrow but if I can't find materials I'll get back to you.
            • Reap3r
              • 596
              #231
              MMMM I like deliveries :)
              Nows where the real fun begins.
              • e30guydownunder
                • Jul 2008
                • 874
                #232
                Man that looks nice! I just been busy playing with my ebay manifold again. You will have to wait for video of the screamer pipe in action. Gate YO!
                Your alternator spacers went in the mail yesty, should get there before the weekend. So is this a local custom jobbie or did you end up going 666fab after everything?
                - Chris
                • Reap3r
                  • 596
                  #233
                  Got it from good & tight. Hopefully things will be looking toward it running boost before xmas or early next year.! Looking forward to getting those spacers. After I get them its just a case of making sure it doesnt leak & plumbing up the custom rad & intercooler setup then off to get exhaust & ecu done!
                  • Reap3r
                    • 596
                    #234
                    Well heres a pic of the manifold & turbo on.
                    Thats about as far as it go, the manifold is most likely going to come off & become a paperweight because the wastegate actuator will not work at all & nobody over here wants to touch stainless manifolds with a 10 foot pole :(
                    Will find out sometime this afternoon hopefully what can be done by the shop that is doing the rest of the exhaust system. It'll be a real shame if the manifold can't be used as it looks well made.
                    • Dj Buttchug
                      • Jun 2010
                      • 7678
                      #235
                      looks good. why not just run an internal wastegate... ?
                      Turbo M42 Build Thread :Here
                      Ig:ryno_pzk
                      I like the tuna here.
                      Originally posted by lambo
                      • Reap3r
                        • 596
                        #236
                        Thats the problem, there is physically no room for the internal gate without doing some serious cutting to the strut tower which is a path I do not want to go down.
                        As you can see thats the wastegate flapper hitting on the strut tower.
                        • e30guydownunder
                          • Jul 2008
                          • 874
                          #237
                          That sucks! You can't make (get made) a bolt on adapter to reposition the turbo slightly? looks like if the flange was closer to horizontal you'd have been sweet!
                          Alternatively fit an external gate and tie the wastegate flapper shut like I have just done on my car? :) everyone loves gate!
                          - Chris
                          • blueapplesoda
                            • Dec 2005
                            • 1904
                            #238
                            Was just gonna say....make a spacer with two turbo flanges and a pipe problem solved
                            • Reap3r
                              • 596
                              #239
                              Off to the exhaust shop, While its there they are looking at modifying the current manifold & adding for the external gate I bought. If not possible a whole manifold will get done along with 3 inch dump, flex, magnaflow cat & 3 inch system through to magnaflow muffler. Also getting braided lines for the turbo feed & drain done & possibly the sump baffles & drain fitting welded into the sump.
                              Meant to get it back early next week. Looking forward to it :D
                              • e30guydownunder
                                • Jul 2008
                                • 874
                                #240
                                Nice man, I'm heading to the dyno AGAIN on Friday....lol my thing is more a dyno queen than anything :(
                                - Chris
