My M60 318is.
  • dirty30
    • 3105
    #121
    New stone guard going on
    Final bay prep
    pre clearcoat pic
    • dirty30
      • 3105
      #122
      Final coat!!
      • ToASTY
        • 23
        #123
        Looks fantastic. I can't wait to see the final product. sub'd.
        Nancy|1991 318is
        Bessy|1985 325e
        • dirty30
          • 3105
          #124
          First time outside since August 2011
          • einarsss
            • Apr 2007
            • 101
            #125
            Nice work and its looks really good :)
            I'm going to steal your idea of using the booster bracket from e32 :D
            E30 3xxi - BRILLANT ROT
            • dirty30
              • 3105
              #126
              It makes things a hell of a lot easier! You'll have to massage that mount a little to get it to fit correctly with the inner fender contour.
              EDIT: Also meant to add my body guy said the inner fender alone wasn't enough structure to endure repeated braking force applied to it. I had plans to beef up the mount area and also brace it against the core support but have since moved to building a boosterless set-up.
              • dirty30
                • 3105
                #127
                Some clearer pictures, can't believe its finally painted!
                • E30ruben
                  • Jul 2011
                  • 448
                  #128
                  Great job! Looks great man love the color.. I personally would've done the engine bay same color. But still looks nice.
                  "Do what you love, and love what you do" -Ray Bradbury
                  • dirty30
                    • 3105
                    #129
                    That was my original plan but it would have been more money to paint body color and the semi flat lets me change things in the bay (weld brackets etc.) and then I can just touch it up myself without a trip back to the body shop.
                    • E30ruben
                      • Jul 2011
                      • 448
                      #130
                      Oh ya good decision man!
                      • bubbajan21
                        • 1962
                        #131
                        Originally posted by dirty30
                        Crash sensors and brackets are gone.
                        Was there anything else required to get rid of the airbag stuff? Did the SRS light come on in the check panel or anything like that or is it just as simple as remove the sensors and swap out the steering wheel?
                        Amazing build! I love the black engine bay. :up:
                        • dirty30
                          • 3105
                          #132
                          I unbolted the sensors, shaved the brackets and pulled the wiring back through the main engine/ body grommet in the firewall. I have a euro upper sunroof crank surround/ front headliner trim panel that is blank where you would normally find the check panel. I also put in a Momo wheel and a spacer I made for the airbag column.
                          • dirty30
                            • 3105
                            #133
                            Masking off
                            • e30guydownunder
                              • Jul 2008
                              • 874
                              #134
                              looks great! awesome result.
                              - Chris
                              Project M42 - 255 @ 19 psi
                              • Hans Gruber
                                • 157
                                #135
                                Update! Sorta...
                                Installed a C02 tank, lines and tap in the shop fridge so not much progress has been made lately. Mounted some e60 style 134 with a set of Hankook R comps I had laying around. Clear the M3 brakes and I won't need to roll the fenders.
                                Great look with these wheels. Did you use a spacer to get them flush? I belive they're 16x7 et20?
                                My Pleasure:02 Honda 954, 02 Fronty 4x4
                                My Pain:91 BMW E30, 90 S13(sr'd)
                                "granthr said: ↑
                                I mention Metric Mechanic because it is a great way to empty your wallet to get unverified horsepower gains."
