DIY paint job. Done right. Hopefully
  • e304me
    • Feb 2006
    • 1374
    Yep I am going to paint my car. Myself. Not some shit in a spray can, a real legit paint job. I have ordered sanding blocks and and a spray gun from eastwood. I am going to be using damn near the best materials I can. The materials cost (excluding the gun and other tools) will be around $1000. This gives you an ideal of why a $2000 paint job is still shitty. I could use 100 bucks worth of some OK paint but instead I am going to use one of the best. because I dont want to have to do this again for as long as I own the car (FOREVER). A gallon of clear and base is going to run me about $700, but to give you an ideal of the quality the clear has a lifetime guarantee when sprayed by a certified technician.
    The east wood stuff should be here tomorrow so I can start sanding. I am going to block sand the current paint to level it out along with fixing all the dents, then I am going to prime and block sand again.
    There are some dents and serious oxizidation in the paint, along with a repair that was done before I got the car that has a peeling clear coat. I am going to fill the antenna hole. Also when I bought the car it was keyed and I thought it would be easy to fix with touchup paint. LOL
    here are some pictures of the car. I will update tomorrow after I get it washed and start sanding.
    here are some scratches, they look worse then they used too because i used a paint scrapper to get the touchup paint off to prep for sanding
    theres there is a crease/dents all along the rocker panel. It is a lot worse than it looks. I am supposed to be getting a good door, this will make it easier.
    repair job that was done before i got the car, If I find a cheap fender I am going to get it.
    here is the car
  • Dj Buttchug
    • Jun 2010
    • 7686
    Prep is the key to a good paint job. good luck man. what color?
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • george graves
      • 20003
      I want to do this too!
      Awesome dude. Except for the spraying - I'm way too chicken.
      I'd love it if you keep track of your material and supplies you use and post up pictures/invoices. No one that does there posts really talks about the supplies they use. Can't wait to see this.
      Originally posted by Matt-B
      • 87e30
        • Jul 2008
        • 5676
        I've thought about this. Someday I'd really like to. Brings a whole new level to do everything yourself. Hmmmm. Keep it updated.
        I just hate everyone.
        No need for discretion.
        • e304me
          • Feb 2006
          • 1374
          Its going to be red. Brilliantrot or muguello. The red on the new m3's is nice too.
          As for the spraying I have watched the paintucation bodywork, paint your own car, and color sanding and buffing DVD's (worth checking out) and i plan to start out on just the trunk. Then doors, then the rest of the car. As long as you mix the paint well and its a non metallic doing one panel at a time is fine. The hardest part is sparying the clear. You have to spary it how you want it to look, so basically you have to soak the car with it while at the same time not getting any runs
          • george graves
            • 20003
            So, why can't you spray 3 or 4 coats of clear so you can color sand your way out of any problems?
            • e304me
              • Feb 2006
              • 1374
              You do spray several coats! There is a run repair tutorial on the paintucation DVD but its a PITA. You cant just sand it. You basically have to pick at it with a razor blade and then sand it
              I have been looking into if you can use lighter coats to avoid runs if you plan to color sand but I cant find any info about it so I am guessing not. I think it will hurt the strength clarity of the clear. I asked kevin at the paintucation forum earlier today we will see what he says.
              • SA E30
                • 1248
                Why not use a 2k paint? Then it's just prep, spray and admire?
                • Frog
                  • Jun 2010
                  • 980
                  Ideal.
                  Winner winner chicken dinner?
                  My Seller Feedback Thread
                  • e304me
                    • Feb 2006
                    • 1374
                    I am using 2k paint. I have looked into single stage (just a base coat) but the paint job will last longer with a clear, and look better as well. It is still in the back of my mind though.
                    • s_ribs
                      • 349
                      Good luck!
                      My only advice:
                      -Prep, prep, prep.
                      -Don't think you can eyeball any surface work for smoothness - guide coat then sand.
                      -Make sure your gun is decent and confirmed to work! Sure sucks when it starts having issues half way through spraying.
                      1991 318i Sedan Project
                      • george graves
                        • 20003
                        What's 2k paint?
                        • Schnitzer318is
                          • Jan 2008
                          • 2057
                          It's a line of paint made by... hmmm the brand escapes me now. I'm sure they'll chime in. I think it might be Dupont?
                          "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
                          91 318is Turbo Sold
                          87 325 Daily driver Sold
                          06 4.8is X5
                          06 Mtec X3
                          05 4.4i X5 Sold
                          92 325ic Sold & Re-purchased
                          90 325i Sold
                          97 328is Sold
                          01 323ci Sold
                          92 325i Sold
                          83 528e Totaled
                          98 328i Sold
                          93 325i Sold
                          • e304me
                            • Feb 2006
                            • 1374
                            No 2k means 2 component. You mix it with a chemical that hardens it. Kind of like epoxy.
                            • Schnitzer318is
                              • Jan 2008
                              • 2057
                              Ah... I stand corrected.
                              91 318is Turbo Sold
                              06 4.8is X5
                              06 Mtec X3
                              05 4.4i X5 Sold
                              90 325i Sold
                              97 328is Sold
                              01 323ci Sold
                              92 325i Sold
                              83 528e Totaled
                              98 328i Sold
                              93 325i Sold
