DIY paint job. Done right. Hopefully
  • Butler
    • Nov 2009
    • 1613
    prep
    prep
    prep
    Good luck.
    -Nick
    Originally posted by 87e30
    First of all: calm the fuck down; second of all; cool story bro.
    • george graves
      • 19996
      Originally posted by e304me
      No 2k means 2 component. You mix it with a chemical that hardens it. Kind of like epoxy.
      Doesn't sound like something a first time DIY'er would want to be spraying.
      Originally posted by Matt-B
      • gtarwiz
        • Jan 2009
        • 591
        I am interested to see how this will come out. I have been wanting to fix my paint for some time now and seeing this just makes me want to do it more.
        BMWCCA # 482566
        Originally posted by nando
        also, I can't think of any BMW special tools you need to do a headgasket on an M20. you could nearly do it with the trunk tool kit, some bubble gum, and string.
        Check out my Leather Shift Boots for Sale Here
        Check out my other work with my GF Here Great gifts for your Wife or GF
        • george graves
          • 19996
          I've been meaning to re-read a thread I saw a while back - some guy with a scirocco does a DIY, first time paint job.
          • 8380 Labs
            • Oct 2006
            • 2990
            Originally posted by Frog
            Ideal.
            :p
            8380 Laboratories
            M3 Champs Poster
            • N2MYE30
              • Oct 2007
              • 5536
              Like the rest, I would like to do this as well. I can get supplies but were will you be shootin this? A make shift booth?
              COTM
              • TwoJ's
                • Oct 2005
                • 4908
                I did a DIY paintjob about a year ago. It actually turned out pretty well.
                Here's the "booth" I made:
                Turned out pretty good:
                Like you already know, it's all in the prep. Make sure you have an absolutely dust free environment to spray in. That is imperative.
                • e304me
                  • Feb 2006
                  • 1374
                  That must be singe stage, you didnt have any fans to circulate air?
                  • e304me
                    • Feb 2006
                    • 1374
                    http://forums.vwvortex.com/showthread.php?4394804
                    hmm thinking about single stage now
                    • e304me
                      • Feb 2006
                      • 1374
                      I guess it doesnt harden it as much as activate the drying? I dont know exactly. All but the shittiest automotive paint jobs use 2k paint
                      • alane
                        • Sep 2007
                        • 376
                        I like your home made booth. PVC?
                        • s_ribs
                          • 345
                          Pretty much all automotive paint, primer, sealer all require mixing an extra ingredient in. Just FYI. They typically use a hardener and a reducer. Both depend on the temp/humidity and adjust the paint properties to cure in varying conditions.
                          1991 318i Sedan Project
                          • george graves
                            • 19996
                            $100 in PVC? More like $200?
                            • TwoJ's
                              • Oct 2005
                              • 4908
                              Yes, it was single stage. How can you tell by looking at it? I did it to make it easier. A few spots had a bit of orange peel, so I ended up color sanding the entire car with 1000, 1500 and 2000. That took a ridiculous amount of time, but it was well worth it.
                              And after those pictures were taken, I put two fans on the side opposite of the filters. That's why I had the HVAC filters -- that's where the air came in. When we were spraying, it was completely sealed in. The plastic on the sides was sucked in very hard. I was actually surprised with how much air moved through there.
                              And yes, it was PVC. I never added up the cost, but it was at least $150, probably more. The pipe wasn't too expensive, but all of those fittings sure were. We had to mop the floor and wet down and wipe the ceiling and walls prior to spraying. It was a bitch to keep clean, but it is very important.
                              • e304me
                                • Feb 2006
                                • 1374
                                We have a barn/garage and I plan just put the plastic on the wall on one side, the ceiling, and another side from from the ceiling but brace it against a trailer, and hang the ends from the ceiling. I plan to have 2 or 3 fans going in with filters and 2 going out.
