TRM E30 Turbo Build
  • Bmw e30 Justin
    • 316
    TRM E30 Turbo Build
    Here I am taking the same path as others...
    I swapped my e30, wanted more power, and a supercharger seemed to be the best solution. As everyone finds out, it's not. After making 342WHP and 260WTQ I was still wanting more. Now, I'm going turbo thanks to TRM's advice and guidance.
    The plan is to do a TRM Stage 1 build using Blunttech's top mount manifold for the 24v swap in a e30; Power goals will be around 350HP and 350TQ with a fat power band and quality parts.
    Planned Specs
    - Stock M52 with S50 cams
    - TRM Stage 1 turbo kit
    - Blunttech's e30 turbo manifold
    - TRM Blow Through MAF and 60LB injectors
    - TRM catch can
    - Tial 44mm wasteage
    - Synapse BOV
    - Southbend Stage 2 Clutch
    - AFX Wideband
    - Custom Intercooler set-up
    Pictures of the car with the supercharger
    Parts are coming in !!!!
  • BUDNUNTA
    • Apr 2005
    • 996
    I like your style
    These chip tune turbo setups are awsome
    TRM get its done
    Whose doing all the Fab work?
    We're out there in here.
    • azael325i
      • Dec 2009
      • 1258
      Turbo is the way I want to go too. Nices e30 sir...
      http://www.r3vlimited.com/board/show...46#post3229446
      • Bmw e30 Justin
        • 316
        Originally posted by BUDNUNTA
        I like your style
        TRM get its done
        A local shop called KGMade, He did all the welding on Dominic49's track car and did all the work when I was supercharged. He does great work his welds are awesome to look at!
        • e30polak
          • 6136
          I approve!
          Should be a monster when you're done with it! :twisted:
          INSTAGRAM: @UNDR8D_EMPIRE
          • einstein57
            • Jun 2007
            • 10780
            350whp? I suspect you'll be upping the boost in no time
            www.gecoils.com
            • blunttech
              • 12850
              Looks great Im going to be embarrassed if youre done before me. What wideband is that in your a/c vent??
              sales@blunttech.com
              www.blunttech.com
              Like us on Facebook
              • dude8383
                • Jan 2005
                • 10387
                God damn thats going to be proper!
                • 5spoke
                  • Sep 2007
                  • 1729
                  Damn dude, this looks killer already. Those seats are so sexy.
                  • 325ix
                    • Aug 2009
                    • 7783
                    I like the wideband in the air vent. Also what wheels are those? I can't tell.
                    • einstein57
                      • Jun 2007
                      • 10780
                      Wheels look like ronal ls' to me.
                      www.gecoils.com
                      • hoveringuy
                        • Dec 2005
                        • 2737
                        Why did you go top mount instead of TRM bottom mount?
                        • Bmw e30 Justin
                          • 316
                          Originally posted by e30polak
                          I approve!
                          Haha thanks man!
                          Haha we will see, right now I'm waiting on the manifold and exhaust housing to get back from being ceramic coated. It's the early style NGK AFX Wideband it worked out great I was proud of myself on that one lol.
                          Thanks that's the plan!
                          We shall see that will require a MLS and headstud's.
                          Thanks and they are Ronal Ls's 15x7.5
                          Well the bottom mount doesn't fit that well, it can be done but it requires spacing the motor over a good bit and some cutting and grinding to make it fit properly. Dominic49 also ran a oil pump system on his car which just seemed like a lot of extra work for little benefit IMO.
                          Dominic's car
                          Oil pump set-up he ran
                          Everything will be wrapped and everything will be ceramic coated so heat shouldn't be an issue on my set-up. Plus Blunttech's top mount manifold seems to be made very well and priced right.
                          • Danny
                            • 14216
                            Excited to see how this turns out. If everything works out the way i'd like it to in the next few months I may be going this route as well.
                            • Good & Tight
                              • Apr 2004
                              • 2057
                              Top mount is the way to go for the E30, our manifolds make it very easy to turbo and keep your a/c also.
                              Can't wait to see the results on this setup. SC power is nice but turbo power is were it's at. You'll be happy for sure.
                              Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                              ____________________________
                              E-mail Panayiotisx2@gmail.com
                              Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
