THE 2002 Turbo build thread
  • fiftytakedowns
    • 2460
    assembly starts thursday:
    ill let some pictures do the talking!
    [/url]
    Team USA Wrestling 67KG
  • Gnarles
    • Dec 2008
    • 342
    Do you like WD40?
    • fiftytakedowns
      • 2460
      I eat sleep and drank that shit
      [/url]
      • fiftytakedowns
        • 2460
        All the parts,
        Finished assembling the Head, and popped out them Freeze plugs. Not pictured, I polished the oil pan, and cleaned the oil pump, as well as the intake manifold and other bits n pieces.
        [/url]
        • Ryann
          • 3350
          r3v could use a little m10.
          cool thread.
          • Dj Buttchug
            • Jun 2010
            • 7686
            noiceee what tarbo?
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
            • fiftytakedowns
              • 2460
              Its a t3 .63 AR 50 Trim garrett Replica. my funding ran out after headwork, cam and forged parts.
              [/url]
              • Dj Buttchug
                • Jun 2010
                • 7686
                hmmm interesting. what you think youll put down hp wise ?
                Ig:ryno_pzk
                • fiftytakedowns
                  • 2460
                  specs are:
                  2L
                  Head: Ported polished SS oversize valves, shrick valve springs. 292 Camshaft
                  bottom end 8.5:1 ofrged pistons.
                  External wastegate turbo-concepts 38 MM
                  should be able to hit 300HP with roughly 15-20 LBs of boost.... It'll rev to like 7000 easy with that head.
                  [/url]
                  • Dj Buttchug
                    • Jun 2010
                    • 7686
                    damn. im hopin to squeeze 300hp out of my turbo m42. its all in the tune.
                    Ig:ryno_pzk
                    • deutschman
                      • May 2008
                      • 5958
                      Super nice! Subscribed.
                      Where did u get your machine work done? I am going to be doing an engine bild soon.
                      Casy motor sport?
                      • fiftytakedowns
                        • 2460
                        Look into cams, Thats where the secret is.
                        700HP 2002
                        [/url]
                        • Dj Buttchug
                          • Jun 2010
                          • 7686
                          700HP 2002
                          holy shit... im on stock cams :( i gotta be able to drive mine in traffic tho. I need good vacuum and a stable idle. not sure if this can be had with an aggressive cam.
                          It seems like with cams you can only move the power either up top or down low, rather than spread the curve out, which can be done up to a certain point.
                          I donno, share some knowledge on this
                          Ig:ryno_pzk
                          • fiftytakedowns
                            • 2460
                            Depends on your goals.
                            Stock Cams can work VERY well, however, you begin to top out rather quickly.
                            cams will definitley move the powerband, however, M42's have adjustable cam gears, so you can adjust the powerband either way. That being said, If you want a badass car your gonna have to care less about your Idle. With more Valve lift you can flow much more air, and rev much more freely. you dont need a hot cam however though, just find out when your Turbo starts spooling, apply powerband, think about how high you want to rev, and then look into cams.
                            with a m42 though, its easy to swap cams, so expirement freely. If you wanna play it safe, just get the same duration, with a higher lift.
                            In a 2002, a camshaft can make 50-100 HP difference in Forced induction applications.
                            If you want more dyno proof:
                            [/url]
                            • LuckyHenriksen
                              • Jun 2010
                              • 4244
                              Sweet project
                              Bahama Beige E23 Project
                              Bluebird Bus Conversion
                              New Oregon Trail
