Eta-to-M50: Build thread
  • Jand3rson
    • 37587
    #1621
    Someday when I have a lift, that will never be a concern again. :)
    • Thrizzle
      • Aug 2011
      • 194
      #1622
      Ahhhhh headers are looking fresh!
        • 37834
        #1623
        Those came out very very nicely. I love the Y-pipe, very clean.
        Grover Beach, California
        BimmerHeads.com
        • Jand3rson
          • 37587
          #1624
          Just got it back in, we started at about 12:30 and had it running just after 4:00 pm. Started on the first crank, too! No issues, the header/Y-pipe combination we built fits perfectly, now I just need to take it in to have the exhaust welded up.
          • dnick
            • Apr 2011
            • 1377
            #1625
            thats great news!
            • Edev
              • 3731
              #1626
              Those are so pretty.
              M Coupe
              • Jand3rson
                • 37587
                #1627
                Oh, and this new shift setup with the UUC DSSR and the AKG Delrin carrier bushing? INSANE. I haven't driven the car yet, but just sitting in it rowing through the gears feels incredible. Less than an inch of play side to side, the lever is centered perfectly in the opening, and it doesn't hit the side of the console when I go into reverse or over into 5th anymore. Just clicks right into each gear and feels solid.
                • 87e30
                  • Jul 2008
                  • 5676
                  #1628
                  Awesome. I can't believe you didn't swap out the shifter sooner... I just had a z3 with stock bushings but even that was an incredible difference.
                  I just hate everyone.
                  No need for discretion.
                  • dnick
                    • Apr 2011
                    • 1377
                    #1629
                    thats awesome.. I have the akg motorsports shifter with just a stock modified selector rod for the g260/m50.. its meh right now because it has a little play.. but what your saying makes me want the dssr even more.
                    • Jand3rson
                      • 37587
                      #1630
                      I've always had the Z3 1.9, but I never changed the knuckle at the front, and I had the sheet metal console before I did the 24V swap.
                      • 2002maniac
                        • 4260
                        #1631
                        fantastic work man. keep it up.
                        • 4ce30
                          • Feb 2006
                          • 2762
                          #1632
                          i love those hi-flow Y pipes, use them on all my exhaust systems..
                          damn 109 page build lol
                          • iwantspeed
                            • 3164
                            #1633
                            this^ plus this picture
                            im excited to install everything and see what it feels like.
                            i have purchased everything except the rear mount bushing into the body.
                            i purchased the uuc evo 3 lever
                            smaller late style knuckle
                            new busing
                            making the delrin shifter bushing with garagistic
                            1)
                            are you using the stock rear mount, i was thinking of making a polyurethane insert into the original bracket.
                            2)
                            I'm also using the AKG Delrin shift carrier bushing, and replaced the shift carrier pin/bitch clip with a shoulder bolt and nylock nut. There is not even the tiniest bit of slop in this shift linkage anymore. I can't wait to see what it feels like to drive this.
                            akg's delrin bushing has the smaller side of the bushing fit inside the shift carrier and not go through the trans case, im wondering whats this black piece that i am pointing at with the red arrow.
                            Project
                            Parts for Sale
                            Feedback
                            YouTube Channel
                            • Jand3rson
                              • 37587
                              #1634
                              Yes, I am using the stock rear mount. That's an area where you do want a little ability to wiggle and flex. The shift carrier is cast aluminum, if you turn it into a rigid structure, you run the very likely risk of snapping it during a hard shift.
                              What you're pointing at with the red arrow is washers, because I didn't want the head of the bolt against that ear, and so I wouldn't have so much thread sticking out the other side.
                              • trackjunkie21
                                • Jan 2010
                                • 3962
                                #1635
                                updates?!?!
                                Originally posted by Wh33lhop
                                VANOS: sometimes you just need to go full retard.
