ttrousdell's Project Thread (E30 M3 & S38 swap content)
  • dothadance
    • Jun 2011
    • 1121
    #151
    SOOOO good. skipped around the first few pages till i saw the m30 and was like "oh, ok". that pier shoot makes your car look like it's owned by a hitman. and lastly, you want to boost an s38!!?!?!?! only good things are happening in this thread, very nice
    • fronton
      • Oct 2009
      • 1262
      #152
      any updates? I am loving this build and hoping you stay naturally aspirated. Have you decided about how to fit it in the e30 yet? What cooling setup, engine height and how far close or into the firewall?
      • ttrousdell
        • Nov 2009
        • 1770
        #153
        Thanks man. Waiting on the machine shop to get the Ross pistons in which should be soon. Sorry darksideofwill, will take your advice on the next one. I have the e30 to s38/m30 block mounts from my m30 and another set that came with the s38. My m30 is 2.5 and the ones that came with the swap are unknown but i have two sets to work with to get me a good position. Im not too worried about getting it to fit. The radiator is custom and will fit in the radiator support where the AC condenser normally is. Im going to use the stock s38 t-stat housing, coolant piping on the front of engine and run a mechanical fan off the water pump. It will be tight. I have yet to make the subframe spacers. I will not be running the stock airbox which might be the higest point so the hood will hopefully clear if thats the case. Megasquirt 3, wideband O2, and Adjustable FPR are here. As a result the MAF and airbox are getting tossed. I will now have space for the stock brake MC. Plannnig on running 6 conical air filters off the ITBs. The exhaust will be 3" to a single flowmaster muffler. Single 3" inlet to a dual 2.5" out.
        Non s38 update, picked up a Ryan G. splitter.....
        ....and my clutch master died after 3 months. Guess I should stop buying the cheap ones.
        The Build:
        • poopin04
          • Jul 2010
          • 1396
          #154
          Tom how many of these have you gone through? Didn't you just change MC recently?
          Click here to leave me feedback on our transactions. :p
          • ttrousdell
            • Nov 2009
            • 1770
            #155
            Just 2. Changed out the slave,mc and rubber line 3 months ago.
            The Build:
            • euroshark
              • Apr 2006
              • 3491
              #156
              Mmmmmm. S38. You are doing it right.
              • e30conv
                • 79
                #157
                What a good build, love your attention to detail and how thorough you have been. Props dude
                • The Dark Side of Will
                  • Jun 2010
                  • 2796
                  #158
                  Eh...
                  It's not my car. ;)
                  Good luck with it! :D
                  Hard to go wrong with an S38...
                  • fronton
                    • Oct 2009
                    • 1262
                    #159
                    I have not seen of heard of any stock BMW mounts working but that's not to say it can't be done. You are correct that it will be a tight fit with the stock cooling pipe and tstat in the lower front passenger side. You will likely need to at least hammer the firewall back for header clearance. With the rad in the AC housing spot you will be running the stock engine fan I assume? That is my setup but I'm tempted to switch to a puller fan which may be more efficient for both cooling and minimal hp loss recovery. I don't have megasquirt experience but it will be nice not having the huge airbox, MAF, and distributer cap as well as much easier access to vacuum and coolant hoses. Without the intake plenum, you might get away without needing subframe spacers but the throttle linkage is nearly as high. Using subframe spacers does give you a less extreme angle for the driveshaft as well as slightly lowers COG obviously but the engine brackets and mounts you use will determine if you'll need them or not. Note that if you use spacers thicker than probably 15mm, you'll want roll center spacers to compensate for the difference in suspension geometry. I made 23mm spacers and used VAC 19mm RCS which require at least 16" rims.
                    • CW325
                      • Jul 2011
                      • 1434
                      #160
                      So what's new with this thing?
                      • downforce22
                        • Aug 2009
                        • 3192
                        #161
                        sick build. Wondering what happened to the m20 and what will happen to the m30. I love the dorm room shots by the way.
                        Also a guy with 700 hp s38 turbo m5 lives less than 50 miles from me. He rebuilt the whole motor and it took him a couple years to build. You may be interested to see his build/process. The car is known as lucifers hammer and the build is on mye28.com.
                        Would love to see updates.
                        • e30m3s54turbo
                          • Jun 2010
                          • 3267
                          #162
                          Any up dates?
                          • ttrousdell
                            • Nov 2009
                            • 1770
                            #163
                            I have not heard of any stock mounts working either. The ones I'm using were custom made. For cooling, I'm planning on using a spal puller fan controlled by the megasquirt. I haven't made the spacers yet. Once the engine is in ill see how much space I need and fab them up. I never considered roll center spacers but if the spacers are greater then 15mm ill have to do some research on those.
                            Wow that engine is beautiful. M20 was sold to F34R last year who hasn't done shit with it. It must suck to be that lazy. :razz: I'm going to leave the m30 in the car until the s38 is done then sell it. Ill be using the 260/6 with the s38. Im glad you appreciate the dorm shots. The response of my schools housing department to an engine in the dorm was quite the opposite.
                            I took the car to an auto-x event for the first time in June. I have a lot to improve on but I recommend it to anyone because it is insane fun. One of the first runs...http://www.youtube.com/watch?v=Ia9LC3nCkDY
                            I finally picked up the S38 parts from the machine shop this Friday after what has felt like an eternity since I dropped it off. The block was hot tanked, over bored to 94.6mm, decked. Crank was polished, new valve guides, valves and seats reconditioned, decked. The rotating mass was balanced.
                            Old rods and piston.
                            So now that most of the peices are here ill be starting the assembly soon. Stay tuned.
                            Recent picture of the car with my buddies 540i.
                            The Build:
                            • F34R
                              sLaughter
                              • 12376
                              #164
                              Yawn.
                              Instagram: @BWeissLeather
                              Current cars:
                              ~ '87 325 M30B35 swap
                              ~ '87 535
                              ~ 01 540 Msport 6spd
                              ~ '06 X5 4.8is
                              • ttrousdell
                                • Nov 2009
                                • 1770
                                #165
                                Evening r3v. Took a break from the s38 to install ground control coils on my car this weekend. Ordered the kit with 440/650 spring rates
                                [ATTACH]62297[/ATTACH]
                                Cutting the strut tube with a pipe cutter. I removed a 2" section.
                                [ATTACH]62298[/ATTACH]
                                Used my 110V mig to weld the new perch on the housing. Used the highest amp setting on that little thing to get the best penetration.
                                [ATTACH]62299[/ATTACH]
                                Rears installed
                                [ATTACH]62300[/ATTACH]
                                Fronts installed.
                                [ATTACH]62301[/ATTACH]
                                The Build:
