Eric's Mtech2 Vert
  • Fyrizon
    • Oct 2012
    • 24
    #151
    Absolutely amazing build, was reading through everything after you posted "batteries" on my silly thread. Now I think I need that steering wheel in my life as well... :(
    Fyrizon
    87' E30 327i Daily
    08' E82 N54+FBO JB4 TiAg SOLD
    08' Z33 VQ35 SOLD
    • Cabriolet
      • 9620
      #152
      Failure sucks
      Melted my rings.
      Checked my compression good in 5/6 of the cylinders. Cylinder 5 register 50psi on the dry compression test and 120 wet.
      Here’s the last time this engine will be in this car.
      Still sexy
      10 am and engine is ready to be pulled.
      My good friend mike lent me a huge hand.
      Breaking lose the shift linkage is always a PITA. The transmission clip sucks.
      11am out it comes.
      Here's the reason I had to do this.
      Melted ring, they crack like glass.
      IMG_0469 by Eric Berger, on Flickr
      Much wow
      I hate 4 doors
      • reelizmpro
        • 9543
        #153
        Didn't you put those rings in? Why only cylinder 5? What brand rings?
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • Cabriolet
          • 9620
          #154
          Barry heres the brand of ring.
          i got the stock OEM size. thinking that would be correct. apparently they were too big. too tight. and built up too much heat.
          Much wow
          I hate 4 doors
          • reelizmpro
            • 9543
            #155
            Didn't check the ring gap? just curious why 1 cylinder and not all. Maybe they would have failed soon as well.
            88 M3 - LACHSSILBER
            • Cabriolet
              • 9620
              #156
              this, cylinder 1 always runs coolest on the M20. my bad, luckily an m20 is a cheap engine to rebuild and i have a bunch of extra m20 engines.
              Much wow
              I hate 4 doors
              • bradnic
                • Jul 2012
                • 3554
                #157
                and this happened with just normal driving?
                HOWTOs:
                DB vert plastic bumpers
                OEM Keys
                MTech1 docs
                88 ix Lach/Card
                91 ic Calypso 3.1
                86 Cosmo 2.7
                OEM+ or bust!
                • canakami
                  • 743
                  #158
                  Damn, you work stupid quick.
                  Always chasin'
                  • Cabriolet
                    • 9620
                    #159
                    Im really not sure what happened. i thought the rings may have been tight, but checking them they are all within spec.
                    today i prepped the block to go in for machining
                    and we also got my wife's rear subframe ready for her car.
                    Much wow
                    I hate 4 doors
                    • craiggroves91
                      • Oct 2009
                      • 3024
                      #160
                      Sucks! You'll get her going soon.
                      PS. You're using the load leveler incorrectly
                      It goes like dis
                      1989 BMW 325i SOLD
                      1998 BMW Estoril Blue e36 M3/4/5 SOLD
                      1987 BMW 325 (The Piece) SOLD
                      1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
                      • Cabriolet
                        • 9620
                        #161
                        The m20 cant use the leveler like that. you will bend the front hanger. so i lift from the motor mount arms
                        Much wow
                        I hate 4 doors
                        • craiggroves91
                          • Oct 2009
                          • 3024
                          #162
                          Its just a hanger, bend it back
                          1989 BMW 325i SOLD
                          • ///schwartzman
                            • Jan 2008
                            • 492
                            #163
                            How much would you sell her with the motor out?? I love M-Tech's almost as much as my M3... and an S54 would make her perfect!
                            Rich!
                            • Cabriolet
                              • 9620
                              #164
                              What what in the butt. It's Christmas break so that means a new engine time!
                              Thanksgiving day all my rings lets go and I had picked up a low millage engine and did a light refresh.
                              Cleaned and painted the block.
                              M50 17lb injectors in.
                              All new seals, timing belt and water pump.
                              Here's our trick for doing the lower seals.
                              Using an engine hoist hold the motor upside-down using chain on the motor mounts. That way we can get to the back seals and oil pan.
                              All put together and ready to go in.
                              In but not running.
                              JK! Blown head or headgasket. Mother F'er!!!
                              So today we did away with that head and gasket for a fully refreshed head, brand new eccentrics (valve adjustment needed badly now.)
                              There's no reason to ever skimp on the headgasket.
                              Head change in 1 day complete!
                              I don't have any photos and I haven't gotten the time-laps for today done yet. but shes running but needs a valve adjustment.
                              Much wow
                              I hate 4 doors
                              • CorvallisBMW
                                Long Schlong Longhammer
                                • 13039
                                #165
                                Holy shit. So you blew one ring, rebuilt it, blew all the rings, got a new engine, blew the HG and then put a new head on? Jesus... that's some bad luck
