Eric's Mtech2 Vert
  • M-technik-3
    • 18946
    #91
    Originally posted by bmwstephen
    pics of the dinan exhaust! anythign spectaculr about it compared to the oem one?
    Thx Corvallis.
    not really. it sounds like shit. drones all the time and there is something loose inside. the IE one weighted almost 1/2 and sounded better. but rubbed on my body kit.
    Because it's a gutted stock exhaust. Love the progress you have made on the car.
    • Cabriolet
      • 9620
      #92
      Yesterday was a super long day. It started with pulling out the entire interior.
      IMG_7519
      All the plastic under the dash had to be removed.
      IMG_7521
      Luke had mentioned that there was no good way to run the battery cable to the trunk on a convertible. I was very worried that this bulge was going to happen to me. But maybe the one he had seen had been done wrong but there is zero bulge in the carpet.
      I took out the door rail and the clear/white plastic wire holder. Then I removed all the clips that hold in the wire-harness under the passenger doorjamb.
      IMG_7513
      After all that was out punching the hole in the firewall is supper easy. Lift the rubber matting and with a hammer tap on the pre-punched plate. I used a chisel to clean up the hole.
      IMG_7523
      IMG_7525
      NOW IF YOU WANT TO DO THIS AND SAVE HOURS READ THIS.
      Remove the rubber boot and run the cable from trunk into passenger compartment then into engine bay. Otherwise you have to bend a hole so that the connecter can fit.
      Run the wire through this hole. Not the little one in the back wall.
      IMG_7515
      Once the wire was run and stretched we mounted it to the front of the car. The holes for this are pre-drilled and accessed by removing the passenger grill.
      IMG_7531
      Wire gets sucked behind this speaker grill.
      IMG_7526
      To ground the car I drilled a hold through the body. Under the bumper so it can’t be seen. Sanded the paint off for a good connection then painted over it.
      IMG_7535
      On the inside I bolt it very tightly.
      IMG_7536
      Then I modded the battery cover, so the strut fits.
      IMG_7532
      Sporting some R3v pride.
      Much wow
      I hate 4 doors
      • bmwphatpat
        • Aug 2011
        • 66
        #93
        props for tackling this on a vert! I've done this on a coupe but was wondering how hard it was on a vert...
        How about the felt liner - how well does it fit with the battery cover? I imagine you'll have to modify it too?
        • Cabriolet
          • 9620
          #94
          please excuse my ignorance. but what/where felt liner?
          Much wow
          I hate 4 doors
          • bmwphatpat
            • Aug 2011
            • 66
            #95
            The carpet/felt/trunk liner that goes on each side of the trunk - you've shown it removed completely to fit the battery cover - you planning on trimming it and replacing or leaving it out completely?
            • Cabriolet
              • 9620
              #96
              oh that, yes i'm gonna mode mine.
              Much wow
              I hate 4 doors
              • reelizmpro
                • 9543
                #97
                Any pics of the dummy weight that used to be where your battery now resides?
                88 M3 - LACHSSILBER
                89 M3 - ALPINEWEISS II
                • Cabriolet
                  • 9620
                  #98
                  Barry, the battery cable it too short. so i have to get it lengthened this week. right now its tired to the wall next to the strut.
                  the dummy weight is the size of the battery tray in a coupe. but weights like 50lbs.
                  Much wow
                  I hate 4 doors
                  • durtyE30
                    • 707
                    #99
                    I was completely unaware that was a complete WEIGHT until this thread!
                    I have a 0 gauge run I did for my stereo amplifier going ot the back anyway, so I'm just going to utilize that and make a new amplifier cable which is shorter. I figured I would have to cut the felt liner as well. I need to get ahold of the battery cover myself, and whatever mounts to hold the battery down (been bitched at for this in autocrosses before while it's in the engine bay, maybe not as bad if it's trunk located, but I don't want to get shit for it next time.)
                    I routed my cable differently, I didn't think there would still be the prepunched hole to punch out, so I just drilled and used a 0-gauge grommet. I obviously don't have the issue of cable length, but I do have the issue that my trunk carpet sticks up a little from where I ran through the rear. I used the holes in the seat backing and just ran straight through there, along with all my RCAs and speaker wire (I ran new speaker wires to each speaker, for impedence and continuity sake....my old radio harness was hacked up.)
                    • Dustn525
                      • Jan 2007
                      • 76
                      #100
                      Looks good! FYI there is a tab to bolt the ground cable to near the wheel well, inside of the "new" battery compartment, no drilling is necessary. I've done this on all 3 of my verts, makes it easy to install an amp. :)
                      I do what I want
                      Past BMWs: '84 325e, '89 325ic, '92 525i, '91 325ic, '89 535i, '86 325es
                      • Cabriolet
                        • 9620
                        #101
                        durtyE30, if you run your cable under the door jam like it did there will be no bump at all and im running bigger than 0gauge.
                        doh! sucks to be me now.
                        Much wow
                        I hate 4 doors
                        • durtyE30
                          • 707
                          #102
                          Thanks for the heads up, I'm tackling this job tomorrow!
                          I have no bumps in my carpet, I'm talking trunk carpet. Where would you pull it through otherwise? I need a bit more picture assistance there or I need to better review what you did.
                          e: after further review, i c wut u did thar.
                          I may do that as well, but I'm not too sure, it's not a big deal to me, but where does it punch through in the trunk? THAT is where I'm confused. I'm going to have to check it out in person more so tomorrow.
                          • Vivek
                            attention whore/retard/bitch
                            • 6167
                            #103
                            What all do you need to relocate the battery, other than a cable from a coupe?
                            1992 Mauritiusblau Vert
                            2011 Alpinweiss 335is coupe
                            2002 540i/6 Black/Black
                            2003 GSX-R 750 (RIP)
                            • IronmanE30
                              • Sep 2009
                              • 2121
                              #104
                              I think that moving the battery to the rear is a good mod. I am planing on doing this to our Mtech very soon. Nice to see some posts on it here before I start.
                              Cheers,
                              Jim
                              • CorvallisBMW
                                Long Schlong Longhammer
                                • 13039
                                #105
                                I just spent the last 12hours wiring in an amp and switching the battery to the trunk. all to find out the the wire was 6" too short.
                                Yes, I know this pain :(
                                The cab's double rear bulkhead means the battery cable has to do a bit more snaking around than in a standard coupe/sedan, which means it ends up being a little short. The solution is to either a) lenghten it, b) make a whole new one or c) use a dremel/sawzall on the bulkheads and make a tiny notch on the bottom corner to allow the cable to pass more "straight" through from the passenger compartment to the trunk.
