2011-2012 Project: Get an S54 running in an E30 using a stock MSS54 DME
  • 2002maniac
    • 4260
    #31
    Originally posted by FredK
    My first pass at the braking system will be the stock 23mm MC with the pivot moved up 1" and attached directly to the firewall sans a booster, with the MC hole moved up an inch as well.
    FredK, you're my hero!
    You'll probably want a smaller MC. We tried a similar setup on my brother's car with the pivot point moved up 1.25" and the pedal was still really hard with the stock MC.
    • dubsport87
      • 282
      #32
      Im keeping my eye on this one.
      Porsche 911
      • Andrew325is
        • Jan 2008
        • 1212
        #33
        I'm stoked to see this post. This hopefully should help a lot. Count me in on helping document this swap. I'm gathering parts right now and I'll soon be making a build thread of my own.
        Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
        • Jean
          • 18228
          #34
          Cool, nice, awesome, epic? :)
          • jakeb
            • 1909
            #35
            This is excellent....
            I have been waiting to swap a S54 into my 01 325xi touring. I know the AWD will handle the power and those parts of it will bolt up. The one thing I have been unsure about is the oil pan. If the e34 pan will fit the m54 xi pan should fit as well... correct?
            Are you going to do all the wiring, programming yourself? When I was looking into it a few months ago I found a tuner in Canada that would handle all the ecu reprogramming for a pretty nice price. Maybe $500...if I remember correctly.
            www.classicdaily.net
            1970 m42 swapped 2002
            1985 LS1/T56 Swapped e28 (557e)
            www.blunttech.com - For all your parts needs
            Follow me on Instagram for constant build updates @classicdaily
            https://www.facebook.com/ClassicDailyLLC
            • eur04lif3
              • Jan 2009
              • 756
              #36
              subscribed! :)
              • dirtysix
                • 806
                #37
                What he said :)
                • Farbin Kaiber
                  Lil' Puppet
                  • 29502
                  #38
                  ff'11?
                  • FredK
                    • 14763
                    #39
                    I'm not sure about the XI oil pan. :(
                    I am not sure who this Canadian guy is, but I'll only be doing the wiring myself.
                    ff'11?
                    I would, if I had a long vacation to drive over there, but I don't. :(
                    • e30polak
                      • 6136
                      #40
                      Cool story bro. Glad to see another person start before me, lol. Look forward to seeing your progress with the brakes, as that's the only hurdle I'm worried about.
                      You're using UweM3's guy from s14 right? It's the same guy from 300mm.de.
                      INSTAGRAM: @UNDR8D_EMPIRE
                      • E30AWDAZ
                        • 399
                        #41
                        Build threads like this gives me hope. I hope that this ends well!
                        • Wh33lhop
                          • 11705
                          #42
                          Awesome.
                          paint sucks
                          • jakeb
                            • 1909
                            #43
                            The place in Canada that I had talked to about programming ews and handling all that is
                            Rpm Motorsport is known for being one of the leading companies in High Performance Tuning and pioneers in replacing BMW / MINI ECUS. With 20 years experience, we proudly offer 3 types of tunes guaranteed to take care of any kind of driver such as Daily Driver, Daily Driver Plus and Xtreme Performance Tunes.
                            • Good & Tight
                              • Apr 2004
                              • 2057
                              #44
                              updates..?
                              Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                              ____________________________
                              E-mail Panayiotisx2@gmail.com
                              Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                              • Spiff325iS
                                • Jun 2004
                                • 1263
                                #45
                                Solid.
                                The Red Dragon V.5 1991 318iS / 2013 F800GT
                                "You gotta fix the nut behind the wheel before you fix the bolts on the car"
