2011-2012 Project: Get an S54 running in an E30 using a stock MSS54 DME
  • Jean
    • 18228
    #91
    H22!!! lolz
    • BrownBeanE30
      • 965
      #92
      bump
      Originally posted by InuFaye
      silver is old man color car. you need dat BRO-SECA BLUE.
      so true.. never let them know where you live..I almost ended up in jail when I was raping young women on craigslist
      An S5x is like the girl you want to marry - an m30 is the girl you don't bring home to mom.
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        #93
        LAWL @ FredJ's avatar.
        • Wh33lhop
          • 11705
          #94
          Lawl @ thread title change.
          paint sucks
          • FredJ
            • Nov 2011
            • 7
            #95
            20 days and no update.
            Amateur hour up in here.
            Originally posted by whysimon
            WTF is hello Kitty (I'm 28 with no kids and I don't have cable)
            • 240zs30
              • 583
              #96
              I have much interest in this thread. Great build so far. I'm going in much the same direction with my swap. What happened to the chopped up the stock headers? did they not fit? I have my ECU in hand and I want to disable things as well need contact info when available.
              • FredK
                • 14763
                #97
                The chopped up stock headers fit fine. However my patience for making a smooth transition between the stock pipes and the 2.125 tubing I had ran out. If I were starting from scratch, I'd use 2.25" tubing all the way to a 2.25" merge collector underneath the car.
                • 240zs30
                  • 583
                  #98
                  Good to know. Looking forward to your next update.
                  • MikeK
                    • Jan 2005
                    • 2771
                    #99
                    bump
                    Toyota Pickup
                    • Farbin Kaiber
                      Lil' Puppet
                      • 29502
                      #100
                      • FredK
                        • 14763
                        #101
                        Werd. I started the engine today. I mostly need to hook up the exhaust, clean up the wiring, and bleed the brakes. The end is in sight!
                        I'm still updating the original posts, though they're kind of boring without any pictures. Haha.
                          • 34844
                          #102
                          *crickets chirping*
                          hehe. finally! so, how many months until you drive it, decide you're bored, and then sell it for a miata? :p
                          • FredK
                            • 14763
                            #103
                            I think I'd have to get a Mazdaspeed3 first, get bored of doing front wheel burnouts and plowing through autocross courses, then move onto a Tacoma and a Miata, while dreaming of a STI BR-Z, an LS3 powered E30, and a six pack of cheesecake frosted red velvet cupcakes. :razz:
                            • craiggroves91
                              • Oct 2009
                              • 3024
                              #104
                              Originally posted by FredK
                              Drivetrain
                              I bought a S3.25 from BenM with a noisy pinion bearing on the cheap. I opened it up and everything was pretty clean, except the torque wasn't set correctly on the pinion gear. The washer got crushed down but somehow the bearings ate themselves up. So, I'm rebuilding it.
                              The friction plates looked OK, so I'm just going to reuse them for the time being. This is my first diff rebuild so I'd rather not dump $250 into machining, an extra dog plate and 3 new friction discs.
                              Hopefully this section has a few more pictures, but PiercedGuy had a pretty good rundown on what's necessary to swap an LSD in. The pinion setup is just a few more steps, but like an idiot I didn't take any pictures of that.
                              Today I set the pinion drag torque. I used a Park TW-1 torque wrench to get to 16 in-lb with the front seal in place. It's the cheapest 0-60 in-lb torque wrench out there, probably, at around $35. I used an E36 fan clutch tool as a counter holder and a long breaker bar to crush the sleeve down.
                              4/30/11
                              I installed the diff after installing the LSD pumpkin. Just need to put new dustcover plates on the output shafts and install the halfshafts.
                              3/11/12
                              I installed a low mileage E36 328i manual driveshaft with a new Lemfoerder E36 M3 flex disc. This required using different flex disc bolts. They were PN 26112283795, and are 4mm longer than the 328i bolts.
                              Is it hard to do the bearings on a diff?
                              I was going to pay to have it done, but it doesn't look too bad?
                              1989 BMW 325i SOLD
                              1998 BMW Estoril Blue e36 M3/4/5 SOLD
                              1987 BMW 325 (The Piece) SOLD
                              1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
                              • FredK
                                • 14763
                                #105
                                It's not that bad, but you'll need a hydraulic press and some bearing/bushing drivers (such as Harbor Freight 95853, which is what I used), and a bearing puller.
                                You'll also probably want a in-lb torque wrench to set the nose bearing preload, unless you want to just do it by feel. I didn't want to risk having to pull the nose bearing again, so I just bought a $35 beam-type Park TW-1 torque wrench.
                                It probably took a couple hours to do the whole job.
