2011-2012 Project: Get an S54 running in an E30 using a stock MSS54 DME
  • craiggroves91
    • Oct 2009
    • 3024
    #106
    Originally posted by FredK
    It's not that bad, but you'll need a hydraulic press and some bearing/bushing drivers (such as Harbor Freight 95853, which is what I used), and a bearing puller.
    You'll also probably want a in-lb torque wrench to set the nose bearing preload, unless you want to just do it by feel. I didn't want to risk having to pull the nose bearing again, so I just bought a $35 beam-type Park TW-1 torque wrench.
    It probably took a couple hours to do the whole job.
    Hm I think I have access to those things.
    I found a shop who would do it for ~$200 which isn't really that bad.
    It's just a loud pinion bearing, like yours.
    Is there any good write ups on it?
    1989 BMW 325i SOLD
    1998 BMW Estoril Blue e36 M3/4/5 SOLD
    1987 BMW 325 (The Piece) SOLD
    1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
    • FredK
      • 14763
      #107
      I just did a "replace bearings" deal, which isn't the same as "building a diff" which would require a little more care in the setup--where you'd set the contact patch between the ring and pinion by way of setting the fore-aft with the shim, and the side-to-side with shim stock.
      The most complete information resource is on the Ohio Bimmers forum in this thread (you must have an account to access it): http://ohiobimmers.com/forum/showthread.php?t=3624
      winfred had a writeup on an OBX Torsen install, and that thread has some pictures of the diff internals that is helpful to rebuilding a diff. He didn't replace the pinion bearing, though.
        • 34844
        #108
        also search for the BMW TIS article on rebuilding a diff. it's pretty much step by step factory instructions.
        • FredJ
          • Nov 2011
          • 7
          #109
          Finally some more good info itt.
          Originally posted by whysimon
          WTF is hello Kitty (I'm 28 with no kids and I don't have cable)
          • FredJ
            • Nov 2011
            • 7
            #110
            New info coming soon guys. Car will be done by 2015, I promise.
            • harv
              • Nov 2004
              • 555
              #111
              This is taking almost as long as my 2002!
              John
              The Revolution will not be televised.
              • airkhin
                • 593
                #112
                im looking forward to more pics of progress..
                • FredJ
                  • Nov 2011
                  • 7
                  #113
                  The car is as done as its getting fellas.
                  Time for a new project. E36 with a LS6 is coming shortly. I will start a thread.
                  • dude8383
                    • Jan 2005
                    • 10387
                    #114
                    Wait wut? Scrapping the s54 project?
                    • FredK
                      • 14763
                      #115
                      Yeah FredJ and I r3ved the car into a fire hydrant on Saturday during a high speed street race.
                      • FredK
                        • 14763
                        #116
                        just kidding.
                        FWIW, the project is essentially done, save for wiring cleanup and DME mounting. I've updated this thread as I've tackled projects here and there. There is sufficient information to duplicate what I've done, including a wiring chart.
                        • VinniE30
                          • 2113
                          #117
                          We need pics and videos!
                          Zinno '89 <24v swap in progress>
                          • Mako18
                            • Jul 2006
                            • 688
                            #118
                            Looking foward to s54 + e30. .. such a nice combo.
                            • dude8383
                              • Jan 2005
                              • 10387
                              #119
                              just kidding.
                              you bastard. i thought you were serious.
                              • Wh33lhop
                                • 11705
                                #120
                                Fredk you need to get us some fucking VIDEO
                                paint sucks
