'90 325i sedan. (bronzit content)
  • womensecks
    • Mar 2012
    • 33
    #316
    :O
    I'm inspired. Keep up the good work. Wish you were closer... I'd love to learn how to fiberglass and weld!
    And probably pay for services, too.
    Not those kinds of services.
    1988 E30 M3, Alpineweiss ///
    iloveyou
    • jaywood
      • Jul 2010
      • 4528
      #317
      Raised up the exhaust more today. 3" exhaust on a low car = not fun.
      • CrusherCurtis
        • 2532
        #318
        What kinda camera/lens you using?
        • Beemer Boy
          • 19
          #319
          Wow!!!!!
          -ROBERT
          1989 325i
          DD & Auto-X
          • jaywood
            • Jul 2010
            • 4528
            #320
            Using a canon rebel ;)
            Finally got the cabin led's in the mail. I was a little worried they would be damaged when they showed up...they were packaged in an envelope with no padding.
            After installing the first one, I was very impressed.
            Then came the 2nd one. It didn't want to work...one of the ends came loose and the solder detached. So I got out this thing
            And soldered it back together
            Done! Still learning how to do those cool night shots...this is my first attempt ;)
            The leds are pretty bright. I like the look a bright white lot more then the stock warm white (yellow)
            • SwiftE30
              • Jun 2010
              • 998
              #321
              what size wheel and tire combo are you running? looks awesome.
              1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
              • Npulver
                • Sep 2011
                • 176
                #322
                Light are SWEET, you just talked me into getting some.
                BTW, love the stance! keeping it going!
                My Build Thread Here (E30) ---> http://www.r3vlimited.com/board/showthread.php?t=240528
                And Here (2002tii) ---> http://www.r3vlimited.com/board/show...35#post3173435
                • AussieTemplar
                  • 107
                  #323
                  Just read all 22 pages and its 2am in Sydney, Australia :)
                  LOVING IT!
                  PS. thanks for the antenna delete plugs, they are a charm :)
                  Nick
                  1989 Australian Delivered 325iS Mtech 2.
                  Fully worked M20B31 stroker. 143kw atw/285ntq atw.
                  • Farintosh
                    • Mar 2012
                    • 38
                    #324
                    Awesome work, Can't imagine how inspiring it is to someone like me.
                    Just bought my first car and have followed along with similar jobs, loving the DIY mentality!
                    • Hybrid For Life
                      • Sep 2011
                      • 37
                      #325
                      And those center caps?
                      • SirWolfian
                        • Mar 2012
                        • 132
                        #326
                        You sir have just made me think about going turbo on my 325i
                        Kudos for your awesome DIY build
                        I Say... that is some awesome shit!
                        '86 325e- (parts car)
                        '89 325i- DD and project aka "Shirley"
                        Progress thread for Shirley
                        • jaywood
                          • Jul 2010
                          • 4528
                          #327
                          Center caps were a complete fail. Going to try again tomorrow maybe. Not sure if I'm up for it yet.
                          Wheels and tires are 16x9 205/40
                          Thanks everyone ! ;)
                          • jaywood
                            • Jul 2010
                            • 4528
                            #328
                            I have yet to mount my gauges. I have the oil pressure and wideband just sitting in front of the shiftboot where the coin tray used to be...and the boost gauge where the 13 button OBC mounts. I decided I wanted a cleaner look so I started on it today.
                            Template #1 (all of these templates are laser cut and scissored paper)
                            #3 in position
                            How the gauges will look
                            I am hoping to finish tomorrow. The final piece will be ABS plastic with a very similar texture to the dash.
                            • jaywood
                              • Jul 2010
                              • 4528
                              #329
                              Did some more on the gauge mounts today. Didn't finish it however. I made an aluminum tray for fun. I wanted to get the angles and what not correct so when I bend the ABS I will know what angle to bend it to.
                              Bender
                              Bent:
                              Test fitted
                              Figured out how to bend ABS with a straight bend
                              Laser cut with some bends in it....Fits very nicely. The reason I went with ABS is because the texture that is on the sheet is very similar to the surrounding dash/center console. Also, I can laser cut it very easily so if I ever want to add an extra gauge it will be very simple ;) The white stuff is residue from something, it wipes right off!
                              It uses the stock mounting points that the original coin tray uses. I will try and get some finished pics tomorrow!
                              • Tuee
                                • 131
                                #330
                                WOW! just read through this whole thing and awesome job!
