E30 M3 Steel Bodywork Conversion
Wow, that's cool... small world. Having that suspension still under the car would have made it infinitely easier for me to pull it home, but I made it back okay, Lol!
I just brought my own 4 lug setup and bolted it on before I left, Lol! I made another big step forward today... see the next post...
Garey
I spent a few hours fitting and welding on the C-pillar today. Got the car prepped and shot with some weld-thru primer, same for the C-pillar. Then I put some new strip caulking in at the base of the C-pillar, since the original stuff was dried out, clamped it on the car for the final time, using about 5 million clamps and started welding. You can see all of the clamps on the rear deck in the first couple of pictures, haha. I plug welded across the roof and under the rear deck, edge welded the inner area to the original window frame and did little 1/2" beads down the pillar from the roof to the quarter, trying to mimic what the factory did for the most part. The fit was pretty good right off the bat, so I didn't have to play around with it too much before I was happy with the fit and could weld it on. After I got done welding, I dressed the welds at the trunk opening and scuffed down the drivers side pillar and gave that a quick shot of primer. Still have a lot of finishing work to do, but it looks pretty good I think...
Hard to believe the C-pillar is actually on the car now...
Garey
WooHoo! Looks great...Comment
Dam man, looks great!! This thread gets better and better every time I read through it. I enjoy watching your work over and over again!! LOL!! Keep it up man!! Mad props my friend!!
And your 540 is the tits!! :up::up:1989 325i|1992 325i|And completely obsessed|:woowoo:
sigpic BMW. The Ultimate Driving Machine.
The Build...Comment
Thanks, mine may be a 'real' M3, but the blood sweat and tears that are giong into your build make yours every bit as special.Comment
Thanks man, here's a better shot of the 540 from last summer...
Garey
I appreciate your support of this build! Not everyone shares your sentiments, but I figure if I'm gonna build an E30 the way I want it, why not go the full monty, right?
Garey
Thanks Bruce... It only took me almost a year to find and secure the donor M3 for the parts for this build... they're out there, you just need a little lady luck on your side to find the "right" candidate. ;)
Garey
I keep inching closer to paint... got some primer on the back half today. Also got the C-pillar seam sealed to the shell across the roof and down the pillars. I needed to get the primer on it so I can seam seal around the rear at the tops of the quarters...
Time for bed...
Garey
agreed.Originally posted by RainierHookerThanks, mine may be a 'real' M3, but the blood sweat and tears that are going into your build make yours every bit as special.
Work of art. You’re a f’ing artist Garey.
You mentioned the making of lists earlier – and it really hit home for me. Some days – out in the shop – I wouldn’t be able to get a damn thing done if I didn’t make lists and goals per day. You make those lists – and start checking things off – and you get to the end goal in a much quicker, methodical manner.
Jesus – I love this build. Wow.
Trying to think how funny it’d be if you put an m10 in there – but yeah, I’m low on sleep..Comment
Thanks man... lists work for me, for some reason. I like the idea of being able to look at it after things get lined out and see what I've done and what's left. Especially if you're taking on the harder tasks first... then you have a list of easy stuff left and that's a big motivator.agreed.
An M10 would be funny... just think of the M60 as 2 M10's on a common crank, if that helps, Lol!
Garey
