Raising the subframe just basically slightly helps correct the rear lowered suspension geometry, but I have the welded adjusters anyway. Really comes down to wanting it solid mounted. The cage ti es into the stud locations, so why not use them even more? :D
Project 88 325is, vert replacement (because racecar content) -- R. I. P.
Ok gotcha! Makes sense! LOL1989 325i|1992 325i|And completely obsessed|:woowoo:
sigpic BMW. The Ultimate Driving Machine.
The Build...Comment
Still waiting on my wilwood parts themselves for the front brakes, all of my hard lines for the rear and probably something else...
I got a box from Turner with their delrin rear diff bushing, and while I was at it, stock blank ate rear rotors and axxis ult/pbr ceramic pads. I picked up some 3M emblem adhesive stuff that should do the job well sealing the lights back up. I've got some work to do at home though before a whole lot more progress shows up.
Got this today..
As much as I hate to, it looks like I need to modify my qrs for my horn ground. Will tap a very small hole in the piece on the side of the steering wheel to terminate the ground side of the horn button. So this is where it stays until I get a 4-40 tap and a really really short screw..
Some new progress..
I got my steering linkage piece in place and the hub/qrs mounted proper. I also used a 4-40 1/4" screw and two #8 washers to ground the horn inside the steering wheel piece through the hub.
Its near the top.
Antenna hole is patched up
..and 25 6-32 1/2" screws with nylocks and #8 washers on each side holding the sunroof panel in. the roof is good enough. I got it a lot closer since the pictures from Jeremy.
nicesigpic
Sick!! This build is beyond win man!1989 325i|1992 325i|And completely obsessed|:woowoo:
The Build...Comment
this looks amazing man. jealous-FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
-The Beauty in the Tragedy-
MECHANIC SMASH!!- (you all know you do it)
Got Drop?? ;-)
Originally posted by JinormusJBut of course
E30s are know to be notoriously really really really ridiculously good lookingComment
