MGB + M42 = Win
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    #136
    Put a nice magnetic plug in that bisch.
    • AndrewBird
      The Mad Scientist
      • 11898
      #137
      Likely will.
      • MikeDE
        • 1873
        #138
        Nice work. Nice rug too, it's Period correct.
        -03/2005 E46 330D Touring 6spd(204hp/410nM) Sapphire Black/Naturbraun Sport...300k KM & 35mpg(mixed)
        • SpoolnDaapex
          • Jan 2010
          • 150
          #139
          I like your bung!
          Was that done on a lathe?
          M42: Because 110 feels like 140 :finger:
          • AndrewBird
            The Mad Scientist
            • 11898
            #140
            Yes, turned by hand on a lathe. Then I tapped it by hand as well.
              • 37832
              #141
              Fuckin sweet dude!
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • AndrewBird
                The Mad Scientist
                • 11898
                #142
                Did a few test welds to get a feel for the sheet metal. Here are the results:
                All nicely ground smooth.
                Plenty of penetration on the back.
                The entire bottom of the pan will be welded this way. Keep in mind I am doing this with 18ga steel and a MIG, not TIG.
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  #143
                  Got most of the bottom welded on. Have to wait to do the last piece or else I won't have access to weld the pick-up tube.
                  Mock-up of the pickup tube.
                  This isn't the tube I will be using, I only used it to see how things would fit. I plan on using a piece of silicone tubing to join the tube that will be welded to the oil pan to the pickup itself. Need to buy some steel tube before I can go any farther.
                  • Jand3rson
                    • 37587
                    #144
                    Excellent progress!
                    • e46s54dr
                      • May 2008
                      • 1059
                      #145
                      Awesome fab work man. Im jealous of your patience to sit there and grind all the welds down super smooth as if it were all one connecting piece. I know for a fact that its pretty tedious work.
                      • AndrewBird
                        The Mad Scientist
                        • 11898
                        #146
                        Actually, it took all of about 10 minutes. lol Angle grinder and a flap disk make quick work of it. It took a lot longer to fit the plate to the rest of the oil pan and get it held in place perfectly.
                        • trackjunkie21
                          • Jan 2010
                          • 3962
                          #147
                          I am incredibly impressed with your fab skills, really wish I had time, money and a welder.
                          Originally posted by Wh33lhop
                          VANOS: sometimes you just need to go full retard.
                          • AndrewBird
                            The Mad Scientist
                            • 11898
                            #148
                            Thanks guys!
                            • metalsoul
                              • 871
                              #149
                              BRo I am so stoked for this project!! I LOVE MGB GT's and have wanted to pick one up for a while now!! Keep up the great work!
                              BUY YOUR KLUB VINTAGE WINDOW DECALS!
                              http://www.r3vlimited.com/board/showthread.php?t=265552
                              Klub Vintage - Classic and specialty car builds and restorations
                              http://www.klubvintage.com
                              Located in Lambertville NJ
                              • BrewCity11
                                • Mar 2008
                                • 2335
                                #150
                                Have you mentioned if you're going to have some sort of a skid plate for that at all? I assume you would; wouldn't take much to dent and put a hole in that.
                                *edit, ok maybe not a hole, but you never know. Welding/grind job looks great.
                                turk@gutenparts.com
