Yoshi's build thread S52 on 1 bar... kinda
  • shiboujin
    • Feb 2006
    • 2791
    #91
    Originally posted by SwiftE30
    great effin build man. Subscribed for sure. One question though, from what i have read, with the size of engine bay the e30's have, heat soaking shouldnt be an issue, so why are you set on water cooling your turbo?
    i only ask because i am starting my turbo build now on my s52 e30 and planned on going w/o water cooling.
    I paid a crap load of money for this turbo. If they put coolant lines on it, I'm gonna run it. Worst case, my turbo runs cooler. I see no down sides other than some extra lines in my bay.
    Originally posted by Ian Bowers
    Yoshi,
    Was it you who was running dual-stock rear calipers for a hydro e-brake setup?
    Going crazy, I know I've seen someone do it.
    I am sir. I had a spare set of trailing arms, cut off the mounting tabs. and welded them on my good ones. Never got the bugs fully out of the system before the last motor went.
    • shiboujin
      • Feb 2006
      • 2791
      #92
      Got too much left to do in the day so I had to quit early.
      Decided to make the red seat the passenger's seat. It's 11 years old but has a much stiffer fixed mount. I figure it's safer for the passengers as my slider for the driver's side isn't considered as safe.
      Of course I found the caliper bolts before the new ones arrive.
      Found the clutch lines. put in brand new clutch masters and slaves. Then found out this thing leaked. It rubbed against the return spring of the clutch pedal and wore through. Removed that dumb spring.
      Stupid clutch lines are really really hard to get to. My glove turned red.
      Put back on the hydro lines and calipers. Still waiting on the rotors. Thankfully the rear is done.
      For anyone who wanted to see the bird eater fix.
      Measured camber. About -5 degrees lol. And the car is in the air.
      • Dj Buttchug
        • Jun 2010
        • 7688
        #93
        dual caliper setup is awesome. do you have pics of the mounting used to make it work?
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • shiboujin
          • Feb 2006
          • 2791
          #94
          I do in some thread somewhere....
          • Ian Bowers
            • Apr 2008
            • 1120
            #95
            I see. I'm doing the same thing for my E30. :)
            • SwiftE30
              • Jun 2010
              • 998
              #96
              [QUOTE=shiboujin;2976784]I paid a crap load of money for this turbo. If they put coolant lines on it, I'm gonna run it. Worst case, my turbo runs cooler. I see no down sides other than some extra lines in my bay.
              Makes sense. I wasnt hatin or anything, just curious. I might have to consider running some cooling lines myself now.
              1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
              • shiboujin
                • Feb 2006
                • 2791
                #97
                def didn't feel any hate :) <3 u!
                • SwiftE30
                  • Jun 2010
                  • 998
                  #98
                  haha aight man. Really lookin forward to how this badboy looks when its sittin on the ground. That rear camber is going to be awesome!
                  whats up with that valve cover hose?
                  • shiboujin
                    • Feb 2006
                    • 2791
                    #99
                    On the ground it has like -9 degrees. I'm going to set the plates to max positive camber. I killed a set of front tires in like 6 months of off and on track driving.
                    The valve cover hose is an adapted 10AN fitting that will be plumbed pre turbo. I've had issues with oil return issues, this fixed it. I don't like the exhaust method.
                    • SwiftE30
                      • Jun 2010
                      • 998
                      #100
                      thats crazy man! Can't be killin tires like that.
                      how pre turbo? on obd1 that is supposed to just circ back into the intake book and ICV connection. where are you planning on plumbing it to?
                      • shiboujin
                        • Feb 2006
                        • 2791
                        #101
                        There's an intake pipe on the turbo (before the turbo). By logic, it will ALWAYS be in vacuum as long as the engine is running. So I just have the hose linking there.
                        I don't run an ICV. I just run a slightly higher idle than normal.
                        • shiboujin
                          • Feb 2006
                          • 2791
                          #102
                          So big steps forward today! I got the wiring harness in. It's still about 80% done but enough that I wanted to get it into the car. I'm waiting on an IAT and pigtail and I need to wire the spark box in, but otherwise I'm doing damn good. I got the M3 cover on. I had to trim things down for the intake manifold and some for the wiring where it goes into the cabin through the old AC line input. Anyone know a better way to mount this against the firewall?
                          Anywho, the big thing is that I got the car to crank over (3 revolutions since I still have no oil in it) and I got the megasquirt to connect to the laptop and to the car. I tested the few that you can without the car cranking/running. Basically, this means my relays (minus the O2 and coil relays) work! The fuel pump even kicked on and primed.
                          Harness cover on
                          cover off. Don't mind the battery tray wiring. That's the part I still have to finish up.
                          Stuff left to do:
                          Turbo coolant lines
                          Turbo drain/feed
                          exhaust fab
                          rear rotors
                          fluids
                          bleed EVERYTHING
                          start it?
                          • SwiftE30
                            • Jun 2010
                            • 998
                            #103
                            nice work! I'm diggin the purple. DOnt know how much it goes with the blue though. haha
                            I didnt know you could run these without the ICV.
                            definitely gettin there man. Nice work.
                            What exhaust set up are you planning on running?
                            • shiboujin
                              • Feb 2006
                              • 2791
                              #104
                              You can run any motor without an ICV. not sure if stock ECUs would like it though. Since I'm full standalone, I can do basically anything within reason.
                              I already have an exhaust from the last setup. 3 inch SS with 2 magnaflow mufflers and a hi flow cat. Pretty much straight back. It's enough that you can hold a convo around the car at idle.
                              • SwiftE30
                                • Jun 2010
                                • 998
                                #105
                                hmm. my next project, other than exhaust setup is building my megasquirt system. Planning on going with megasquirt 3 w/ MSX3 for sull sequential, so i guess getting rid of my ICV at that point would be sweet. and yeah im assumign the stock 413 red label wouldnt like not having an ICV. My first ICV was completely stuck when i first started the car and it just completely flood the engine and kill it after about a minute of running.
                                How come you are going with two mufflers when you are running a turbo? Just because you already have it fabbed up? I figured the turbo acts as a muffler so only a highflow cat and single muffler would work fine and still be able to "hold a convo around the car at idle." haha. never heard someone refer to exhaust like that. nice one.
