The Turbo 325ix build!
  • IxTech
    • 471
    #106
    Went to start it tonight. Not getting any spark....swapped cps and cid. Hoping to god its not my megasquirt? Anyone know how to test if my megasquirt is sending spark signal? Gonna swap a different cps in tomorrow, although the one that im using now is the one that was already in the car.
    http://r3vlimited.com/board/showthread.php?t=201774
    • IxTech
      • 471
      #107
      Swapped a customers cps in and it fired right up. Soooo....wtb cps! Holla
      • litu
        • 848
        #108
        Whit those rotas. looks heavenly :). Probs
        https://www.facebook.com/Cry_77_IX-110483784967661
        https://www.instagram.com/cry_77_ix/
        • kid325e
          • Sep 2007
          • 6422
          #109
          Let me know if you have trouble finding one. I may have one laying around the garage or at least at the shop I work at. We probably stock it.
          clutchCTRL!
          Move with a purpose.
          - 1991 325iX 4dr/5spd
          - 2000 323i AT
          2016 Mazda CX3 Sport AWD
          • IxTech
            • 471
            #110
            Thanks but i just got one on the wtb section. Gonna redo my engine constants in tunerstudio, wire up the analog output for ve analyzer, bleed my slave cyl, and go for a drive. Cant fucking wait
            • IxTech
              • 471
              #111
              Shes running really nice and im happy with how the cars sitting now. Need to head to dyno and get few adjustments made then put down some numbers. Priority #1 is get to bremerton open drift on 9/30
              • kid325e
                • Sep 2007
                • 6422
                #112
                Fuuu maybe i'll come out and watch you!
                clutchCTRL!
                - 2000 323i AT
                • IxTech
                  • 471
                  #113
                  Hell yeah! Need some more e30 fans at the track. Gonna try to make it to south south sound speedway first and get a few things adjusted. But ultimately would like to get to bremerton.
                  • IxTech
                    • 471
                    #114
                    Went out last night with some buddies for a stroll. Had a great time with some good people.
                    • IxTech
                      • 471
                      #115
                      • dpgc44
                        • Aug 2012
                        • 11
                        #116
                        Man nice ride, this is the route I am going as well. Got a 1991 IX 153k on it. Going to do a rebuild and turbo it. Not looking for anything crazy just a faster car. Some people should also respect the Vtec as I own a 88 hatch that has taken down many a 335I's 2300 with me in it. B20Vtec with full interior. Many people talk trash but don't knock it till you try it. Anyways I am on to this project and would ask you guys some questions if you guys don't mind.
                        • downforce22
                          • Aug 2009
                          • 3193
                          #117
                          ^^ whats your plan for management dpgc44?
                          • IxTech
                            • 471
                            #118
                            Guys just get pnp megasquirt from keith. Miller is a TERRIBLE SYSTEM YOU WILL HATE YOUR LIFE. Ive done 2 cars on it now and its always been a bitch
                            • dpgc44
                              • Aug 2012
                              • 11
                              #119
                              Researching this as I am in no way an E30 expert. What head gasket setup did you use? I have to replace that now as I have a huge oil leak and am pretty sure that the old gasket is on it's way out. I was also going to get the arp headbolt setup to get that out of the way.
                              • IxTech
                                • 471
                                #120
                                I have metric blues and a cometic .120 mls. I hate it, leaks oil like a bitch but ill never blow it till i crack my head.
                                If youre boosting you have a couple different combinations to consider.
                                A tried and true favorite is a stock gasket crushed onto o-rings using ARP studs. If your block and head are super flat, you shouldnt have an issue with an mls if you use studs. Id throw some spray on it anyways though. On lower boost, a stock gasket w/ no orings with metric blues works okay. I wouldnt take it over 10psi though. Its a good low cost solution. Id put metric blues on any car thats going to be driven hard, not to
                                Mention theyre way cheaper than stock bolts. But go read up, theres a lot more good info out there and whole threads dedicated to HG combos for different applications
