Andrew's 1989 325i Project
  • KenC
    King of Kegstands
    • 14396
    #376
    I don't trust the ball joints to last... the boots are crap too. But if you're planning on replacing them in a year or so, go ahead.
    Originally posted by Gruelius
    • MattAvino
      • Jan 2011
      • 2147
      #377
      I seriously considered those parts from FCP groton. I came to my senses and went with blunttech instead. I'm very happy I made that decision.
      E30 buildy things
      http://www.r3vlimited.com/board/showthread.php?t=195286
      • 5Toes
        • 9836
        #378
        Ugh, I need to think about this hard
        So driver side control arm is off... passenger side is almost there. The 22mm bolt I can get my wrench on, but no room to turn it. SO I gotta borrow a 22mm socket from a friend or autozone or something
        • 5Toes
          • 9836
          #379
          figured out the no start issue today. it is definitely the fpr... clamped the fuel line halfway and it started right up
          • 5Toes
            • 9836
            #380
            Well adjusted the valves today. I took one mans advice on bimmerforums and did them to .008 inches. Nice and quiet now. Lastnight my engine knock got atrocious...
            SO new m20b25 time!!!!
            • Jparkr
              HR Admin
              • Jan 2006
              • 3494
              #381
              I adjusted your valves for you what, 3 months ago? The noise probably got louder because you screwed it all up.
              1987 PRO-3 car /1990 325is (2.7i Concours)
              • 5Toes
                • 9836
                #382
                We adjusted the valves together back in June or May. Reading on here I figured that last night when the noise got super loud that I had broke a rocker, though today when examining them all I saw zero cracks. I was adjusting the valves just to make sure that the noise is from the bottom end. I have seen videos on youtube of people confusing rod knock with a loose rocker
                • CW325
                  • Jul 2011
                  • 1434
                  #383
                  Seems like you just want an excuse for an engine swap!
                  • 5Toes
                    • 9836
                    #384
                    Well why pull an engine to do new rods, when I can prep a new engine to be dropped in? Besides... me rebuilding an engine would be *bad*
                      • 37832
                      #385
                      That's too tight on the valves, readjust them to the correct spec.
                      Classic BMW Specialists
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • MKorodini
                        • Jan 2009
                        • 36
                        #386
                        Just read you entire thread. Kudos to you man! I enjoyed all the ups and downs. Good luck with the e30!
                        • 5Toes
                          • 9836
                          #387
                          MR 325, I had read by other E30 drivers that the tighter spec I used worked great and they have gone 15,000 miles no problems. Their explanation, that the shorter the distance the less force is put on the rocker makes sense.
                          Either way, doesnt matter cause I found myself an engine!
                          • 5Toes
                            • 9836
                            #388
                            Originally posted by jlevie
                            The slightly tighter valve setting isn't likely to be the cause of the rough idle. I use 0.006 for the intakes and 0.008 for the exhausts on my Spec E30 and it doesn't affect idle. The rough idle is more likely to be the result of intake leaks. A smoke test of the intake is the way to find the leaks.
                            From Jlevie... very knowledgeable man on M20's
                            • 5Toes
                              • 9836
                              #389
                              Found an engine! Thank you so much BMWm42.
                              So list of things to order so far:
                              - Upper gasket/head gasket set
                              - Lower Gasket Set
                              - Timing Belt Kit
                              - I am going to reuse my water pump, it has only about 2000 miles, should be fine. Will buy a new gasket for it though and clean it up
                              - Distributor Cap (plug wires I will purchase later, easy to do with engine in car)
                              - Cap
                              - Intake Boot
                              - Random Seals/Gaskets
                              - Purple Power, Brake Cleaner, Etc.
                              - Might as well get new motor mounts. Any OEM+ stuff that will work (M5 or something..)
                              Anything else you guys can think of? This list is nowhere near complete, however I would love some input
                              Looking at about a $400 parts order right now
                              • george graves
                                • 20003
                                #390
                                Why re-gasket the motor? Is it really leaking?
                                Originally posted by Matt-B
