M20B29 w/ Triple Webers into my '71 2002
  • 2mAn
    SeƱior Mod
    • 20336
    #301
    looks great Andrew! Those pics of Robs "workshop" gives me bad ideas
    Simon
    Current Cars:
    -1966 Lotus Elan
    -1986 German Car
    -2006 Volkswagen Jetta TDI
    Make R3V Great Again -2020
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      #302
      ^ what he said.
      1991 318i 4dr slick top
      Mtech 2 turbo restoration
      • SkiFree
        • Jun 2011
        • 2766
        #303
        ^ what he said.
        Just for your car ....
        Large capacity oil pan (that conveniently helps with with under-car aero).
        Just to better illustrate how crazy the shop is .... here's the restroom. Complete with diffs and a lower tii timing cover.
        ADAMS Autosport
        • SkiFree
          • Jun 2011
          • 2766
          #304
          Starting to fiddle with the coolant system prior to mocking up the engine.
          So it looks like the chopped e30/e36 aluminum radiator is going to fit underneath the top tray.
          This meant welding a standoff on the belt cover so I can run the 325i coolant crossover pipe.
          ..... and in the spirit of not taking things too seriously I give you the heim-jointed alternator tensioner!
          ADAMS Autosport
          • ThatOneEuroE30
            • Dec 2013
            • 8626
            #305
            Bahaha that oil pan is aweseome. Looks like they made it once and decided they needed more oil capacity. Maybe that will cure the loss of oil pressure in corners haha
            • digger
              • Nov 2005
              • 6015
              #306
              how long until you crank her over?
              • SkiFree
                • Jun 2011
                • 2766
                #307
                1 year, that's the goal to have the car driving. Want to take it to Monterey Historics for all the BMW events.
                The engine is going in for mockup before the end of the week.
                ADAMS Autosport
                • Brad Sindoni
                  • Nov 2014
                  • 178
                  #308
                  This is the best build thread I think I've ever seen on here. A lot of props to you for your patience along the way. Can not wait to see more.
                  _keepitgutter
                  88 Alpine white Super Eta
                  • stonea
                    • 2892
                    #309
                    Sub'd :D
                    My Garage
                    Feedback
                    Instagram: Stone.Hopkins
                    • JasonBates
                      • 265
                      #310
                      I totally just made some of these for my car. That one looks quite a lot better than mine do.
                      '87 325e 2.7i/5spd
                      '02 Subaru outback (Still smells like dirty hippie)
                      '86 635csi (Sold)
                      '87 4KcsQT (Sold)
                      '84 318i (Sold)
                      • SkiFree
                        • Jun 2011
                        • 2766
                        #311
                        Awesome ... as for looks, nothing a bit of scotchbright can't fix.
                        Alright, an update!
                        First up, the radiator itself. As mentioned in the past, its just an e30/e36 aluminum radiator that has had the bottom wacked off.
                        Trimmed the front sheet metal so I can slide in the radiator.
                        There should be plenty of room at that point for the motor to sit, BUT I want to be able to remove the radiator while in the car, so I'll be cutting and making a portion of the upper section removable.
                        Hooked up the engine to a scale. This plus the headers will be the weight going into the 2002. Going to compile a good list of weights of various options for future reference.
                        ADAMS Autosport
                        • 88SuperETABD
                          • Apr 2009
                          • 911
                          #312
                          M20-2.9L + ITB's into '71 2002
                          Wow, the m20 really doesn't weigh much. What's a m10 weigh in similar config? Does this have oil in it? Or is that dry weight? All your carbs/itb's are probably Heavier than the fuel rail/intake right?
                          Keep up the updates :)
                          (SOLD) 1988 327i Build Thread: http://www.r3vlimited.com/board/showthread.php?t=155086
                          1970 Gruppe 2 2902 M20 Turbo Build: http://www.r3vlimited.com/board/showthread.php?t=373891
                          • digger
                            • Nov 2005
                            • 6015
                            #313
                            wow thats heavier than i though. the bare block and crank is about 150lb, so all the other stuff adds up
                            • SkiFree
                              • Jun 2011
                              • 2766
                              #314
                              This is dry weight. I will be weighing everything as things progress. Very curious to see if I can get to a stock 2002 weight without going overboard.
                              This weight does include the 3.5# chain though.
                              ADAMS Autosport
                              • 88SuperETABD
                                • Apr 2009
                                • 911
                                #315
                                You using factory hood? My hood is jacked up so I'll be getting a fiberglass one and pins. So that's a lot of weight.
