1991 Mtech Build
  • Unearth078
    • May 2008
    • 2623
    #46
    Originally posted by IronmanE30
    Yes, the car is an airbag car and yes we used spacers/washers. The turn signals return works. When we installed it with the stock spacer the wheel rubbed slightly on the plastic steering column surround so we added one thick washer to make that go away.
    can you shed more light on this? ive never had an airbag car until now, and this seems as if my issue with my mom. you would just space the back of the wheel until it works?>
    Originally posted by Lof8
    4 doors allow you to transport more whores.
    therefore, their value is much greater.
    Down to: 89 aw2 332i/4/5 , 70 Sahara 2002
    • IronmanE30
      • Sep 2009
      • 2121
      #47
      Early non air bag cars have a spacer (P/N 32311120260) that compensates for the room that the air bag steering wheels have. If you put a non-airbag steering wheel on an air bag car you will need to place the spacer on the steering shaft before you put on the steering wheel. Some folks use washers to make up for the spacer some buy the spacer which is not that expensive (under $10).Depending on which steering wheel and hub you use you may need an extra washer to make keep the steering wheel from rubbing on the plastic steering column surround. Another issue is that if you space the steering wheel out too much your turn signal will not automatically return to the neutral position. I also swapped out the turn signal stalk from an early model car because the bend on the early models give you more room between the steering wheel and the turn signal stalk. There are lots of threads on this here on R3V that will give you detailed installation instructions. Hope this help.
      Cheers,
      Jim
      • robrez
        • Jul 2008
        • 3376
        #48
        Looking good. I've been lagging even more than you on my m-tech vert restoration, but when you're ready to get your upholstery done, let me know. Maybe we can get a two-for-one discount
        January 2012 COTM
        • IronmanE30
          • Sep 2009
          • 2121
          #49
          Hi Robert, It's funny how long it takes to get things done on our cars when we have so many project going on at the same time. I took the Mtech down to Jim's Upholstery in San Diego and got a quote of $1275 to redo the door cards in vinyl and seats in new leather using the Mtech fabric, that we have, in the appropriate places. I also had them give me a quote of $1200 to redo the hard top inside and out. Ouch! They do exceptional work and that is where I will end up taking the car once I have saved up the cash. My plan is to take all the parts down in my pickup so they don't have the car just sitting in the parking lot while they are doing the work. I can fit both of our parts in one truck load and see if they will give us a break on the cost. If you are still interested we can talk before I go down there in a couple of months.
          Cheers,
          Jim
          • !AjHoWzA!
            • Jan 2010
            • 1140
            #50
            Wow, an amazing build you have here! I'm loving it!
            '91 318is
            • IronmanE30
              • Sep 2009
              • 2121
              #51
              Thanks, I wish it could go a little faster.
              Cheers,
              Jim
              • e30m3s54turbo
                • Jun 2010
                • 3277
                #52
                Looks great Jim.
                • Court M3
                  • Jan 2004
                  • 6713
                  #53
                  Turned out real nice! Oh and I want that shirt.
                  Continuous For Sale Thread
                  323i s50
                  • IronmanE30
                    • Sep 2009
                    • 2121
                    #54
                    Originally posted by e30m3s54turbo
                    Looks great Jim.
                    Thanks Raul for all you help with this build.
                    Thanks! PM me you shirt size and I will see what I can do. The young lad in the picture is my son who works there as a technician.
                    Cheers,
                    Jim
                    • e30m3s54turbo
                      • Jun 2010
                      • 3277
                      #55
                      Hey buddy when are you going to install those mono wipers Mtech II an m3?
                      • IronmanE30
                        • Sep 2009
                        • 2121
                        #56
                        Sounds like I may have time next week to mock up the first set. Bring by that one you just got so I can check it out.
                        Cheers,
                        Jim
                        • IronmanE30
                          • Sep 2009
                          • 2121
                          #57
                          It has been a while, so here's a little update. Mono wiper installed.
                          Cheers,
                          Jim
                          • e30m3s54turbo
                            • Jun 2010
                            • 3277
                            #58
                            Looks good buddy.
                              • 37832
                              #59
                              Wow, I like it!
                              Classic BMW Specialists
                              Grover Beach, CA
                              www.BimmerHeads.com
                              • cactusjacks1
                                • Sep 2004
                                • 1216
                                #60
                                You are the man !!! Nicely done - looks OEM & only costs twice as much ........LOL
                                [I
