/// New 24v Henna Track Toy
  • M-technik-3
    • 18946
    #61
    Odd, never seen that. All M3's are that way and I have never seen a broken one.
    Sway bars
    The M3 uses a different sway bar mounting setup than other E36 models. On E36 M3s, the sway bar mounts to the strut instead of the control arm (see Photo 7). Mounting the sway bar on top of the strut allows the sway bar to be more effective than the stock mounting location. The actual geometry and mounting configuration of the M3 roll bar and the regular E36 roll bar are nearly identical; the main difference is in this drop link setup. Most aftermarket manufacturers only offer sway bars for the M3 models, but they will also fit other E36s. However, due to the change in this drop link orientation, sway bars have varying degrees of effectiveness, depending upon whether they’re installed on an M3 or an E36.
    This is important for a variety of reasons. Installing a sway bar designed for an M3 into a stock E36 setup will work fine; however, it will not give the exact effect the manufacturer originally designed it to have. If you wish to upgrade your sway bars, choose an aftermarket M3 set that will produce a measured increase in anti-roll stiffness while balancing the changes with upgraded springs and stiffer shocks. To demonstrate this difference in sway bar effectiveness, compare the various sizes of stock sway bars:
    Model
    Front bar
    Rear bar
    Stock 95 M3
    22.5 millimeters
    19 millimeters
    Stock 96+ M3
    23 millimeters
    20 millimeters
    Stock 328i
    24 millimeters
    15 millimeters
    Stock 328i Sport
    25.5 millimeters
    18 millimeters
    The front sway bar for the M3 is thinner than the stock sway bar for the 328 because the sway bar drop linkage on the M3 is more effective and doesn’t require a heavier, thicker bar.
    If you select the PSS suspension system for your M3, first convert the sway bar drop links to the stock E36 setup. You will lose some of your effective anti-roll capabilities because of the shorter drop link configuration used on the stock cars. Counter this by installing a beefier sway bar at the same time. The conversion to the stock drop links is easy and requires only about $40 worth of parts. Here are the part numbers required for this conversion:
    • Luis325
      • 3847
      #62
      Thanks for the info greg i will look i to this!!
      Also any help on what tire size to run????? I want meaty tires.. Looking into runing 245/45/6 toyos R 888.
      Any sugestions? Wheels are 9" wide!
      1986 "C2 2.7 Alpina" Sedan
      1987 325ic Black Vert
      • markseven
        • Sep 2006
        • 5327
        #63
        Originally posted by Luis325
        i just talked it over with my mechanic and he said to not to change it and that i should leave it in the control arm...
        That up in the strut they break allot easier...
        Nice build!
        Your mechanic is mistaken.
        I Timothy 2:1-2
        • blunttech
          • 12850
          #64
          wow awesome build I need to make more time to scour the boards Too busy and I miss this stuff.
          Tell me about the flap Luis. I just got the same spoiler for my car and need to buy the flap. Does it come with hardware? All I got was the spoiler
          sales@blunttech.com
          www.blunttech.com
          Like us on Facebook
          • Luis325
            • 3847
            #65
            Thanks Steve, i got the flap from Ary @ Dtm fiberwerkz. No harware..It fits perfectly in the zender spoiler but the only hick up is the holes are not the same ... They dont line up from the flap on the spoiler... Nothing that cant be fixed easily... Cause trying to find the flap alone is pretty dificult. But if your in no hurry ask ACNico he might be abble to get you a zender one!
            • M-technik-3
              • 18946
              #66
              That one I got I had lying about for some time. They are by no means common these days.
              • Luis325
                • 3847
                #67
                ^^You have the flap too?? Haha
                Btw any help onnthe tire sizes???
                And any suggestions on what adjustable m3 sway links to buy???
                • Luis325
                  • 3847
                  #68
                  Not much going on... Too much work but we are getting closer lol..
                  Rear suspension done, got the camber and toe adjusters welded in this weekend and Sunroof casset removed! Car in finally on the floor after 1 year lol.
                  Still Gathering a few more parts.. Pics soon...
                  • Luis325
                    • 3847
                    #69
                    • kingston
                      • Jun 2010
                      • 2669
                      #70
                      PURTEE!!!!! I am SO d*mn jealous of the 5-lug stuff!
                      Can't wait to see more updates! Looks like you're really making progress!
                      Originally posted by LJ851
                      kingston is the play by play announcer for this thread.
                      ‘Tis by the grace of God that my cars run!
                      Originally posted by unloadedak
                      #teamross
                      Siobhan's Build Thread - UPDATED!
                      • e30_neverstock
                        • Nov 2011
                        • 283
                        #71
                        what kind of cage is that?
                        • catuned
                          • Jun 2011
                          • 2324
                          #72
                          LUIS,
                          OMG.. I don't know why I didn't see your car earlier.. Awesome job Man!
                          Love it. Your car will be total fun! Hope to get mine done. It's hard to get everything done. Never enough time in the day! Good luck hope you get it done before I do. :)
                          Work We Do
                          CAtuned Feedback Page|FB CAtuned Page
                          http://www.catuned.com
                          • Luis325
                            • 3847
                            #73
                            ^ Thanks CAtuned... Still havent done shit with the car haha, its just sad in the garage, not even had time to weld the cage... May 9th finally its getting picked up and taken to the shop where itwill be welded...
                            I Need to finish it by july so will see.....
                            • catuned
                              • Jun 2011
                              • 2324
                              #74
                              I know how it is.
                              Work We Do
                              • Luis325
                                • 3847
                                #75
                                We have progress!!! Finally left today to get the cage FINALLY done and then some good Henna paint sexyness!!!
                                Should have her back next week from the cage guy then on to the paint!!!
