This Is Randomness(and my build thread, I swear).
  • FunfGan
    • Jan 2011
    • 4958
    #91
    Hahah, sounds good man. Cant wait till we can all cruise in these bad boys... You with an m50, spencer with a turbo m42 and then the m62...
    Go here be happy!
    Ratchet Garage e30 V8 build.
    • dnick
      • Apr 2011
      • 1377
      #92
      hell yes! i cant wait.. and woah... spencer turbo???? when!
      • dnick
        • Apr 2011
        • 1377
        #93
        edit.. i remember u told me. lol
        • FunfGan
          • Jan 2011
          • 4958
          #94
          Like my new camberz?:
          Ok but seriously, I'd like to run 15mm spacers in the rear for the street. Time to get to work...
          Go here be happy!
          • Dj Buttchug
            • Jun 2010
            • 7686
            #95
            gayyyyy boiiiizzz
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
            • VinniE30
              • 2113
              #96
              Can the e30 rear end even handle that much power?
              ...Or are you just going to find out?
              Zinno '89 <24v swap in progress>
              • Vtec?lol
                • Dec 2009
                • 3278
                #97
                sry if I'm late but, why is there an tachometer in front of your tachometer?
                • FunfGan
                  • Jan 2011
                  • 4958
                  #98
                  I've got a 2.73 lsd going in, which is the recommended diff for the swap. Its looking a lot less difficult of a swap then I thought.
                  Because racecar.
                  Go here be happy!
                  • Vtec?lol
                    • Dec 2009
                    • 3278
                    #99
                    But? sigh, nvm. looks like a fun setup though
                    • FunfGan
                      • Jan 2011
                      • 4958
                      #100
                      But? sigh, nvm.
                      Hahah, sorry. Was there when I bought it. I dig it, but I'm curious to see if the tach was actually messed up or what the case was... Its kind of a part of the car now, if not a bit redundant.
                      Go here be happy!
                      • Vtec?lol
                        • Dec 2009
                        • 3278
                        #101
                        does the original work?
                        • FunfGan
                          • Jan 2011
                          • 4958
                          #102
                          Not right now, but I assume the aftermarket one is wired directly into the tach wiring, as apposed to tapped into the wires. That probably makes no sense.
                          Oh, and I saw that ninja edit. I lol'd.
                          Go here be happy!
                          • VinniE30
                            • 2113
                            #103
                            How about the rest of the rear suspension? How about the subframe? I'd be worried about more than the differential.
                            • FunfGan
                              • Jan 2011
                              • 4958
                              #104
                              Ive read a pretty thorough build thread on it and It says that the stock subframe etc is fine. Now when it comes time for the s62 cams I'll definitely be doing poly rear subframe mounts and an m3 diff. In fact, if I use a 5spd trans for it(as apposed to the 6spd), I can use the stock trans mounts and a stock driveshaft. Even the rad doesn't need special fab work. So really, I just have to get engine mounts made, and modify the brake booster and figure out wiring. The build I found even has a very clear, easy to use diagram for making a plug and play harness adapter. For the other stuff, theres apparently a guy near by who's done the swap so I'll be talking to him for help. Can two 17 year olds perform a m62 engine swap in a tiny garage? I guess we'll find out haha.
                              Go here be happy!
                              • Wh33lhop
                                • 11705
                                #105
                                I am still waiting for this 420hp M62...
                                paint sucks
