Well, they are different, but the same too. This sort of sums it up:
So we can agree and disagree. I think the swastika has been made to mean something other than just another national symbol, but the Nazis weren't the ones who assigned it that meaning.
On the scoops - does air flow from top to bottom or from down to up
inside the engine compartment? It's possible that scoops could impede
flow by adding pressure that works against the way it was designed to flow. So it would either help or hurt, depending on the situation. It'd
be interesting to experiment with.
The vents will help cool under the hood, and the backwards scoops
you planned shouldn't change that by much. They could help pull air
up and out.
While the SS used the Balkankreuz along with the Wehrmacht (the German navy continued to use the older style iron cross), the old cross and Balkenkreuz were never associated with the SS to the degree that the swastika was. The current German military still uses the Balkenkreuz extensively, whereas the swastika (Hakenkreuz) is illegal in Germany.
up and out.
