What color are you going to spray the car? You ever think about doing truck bed coating on the bay to kinda hide more imperfections?
The complete repair, rebuild, repaint, and v8 swap of my early model sedan
No I didn't, and it sounds like a good idea, even if just for the durability reasons. Unfortunately, I don't think I'll be able to get a truck bed coating in anything even remotely close to the color I chose.
Honestly, I'm not much of a car show person. The only person that will see under the hood is me. I want it to look decent, but I'm not all that concerned.Comment
there is coatings that you can paint over and there is coatings that you can mix your color in and spray. I will look it up and report back. :)Comment
Garey
damn man! your doing some serious work! A lot or props to you for fixing it all instead of getting a new shell. I love it. Def sub'dComment
Thanks man!Comment
I'm probably doing something wrong, just didn't figure it out yet. hahaComment
Most welders will have the spool, then a washer, then a spring, and then a nut to tighten it all down. Try messing around with it and maybe updating with a few of your own parts. I HATE MIG wire birds nests!sigpic
Interesting. I have no spring. That sounds like something that would help! I'll swing by the hardware store, they carry Lincoln parts, I'm sure they have some sort of hardware kit.
I need to get a 90 degree fitting for the gas hose in the back of the welder anyway. The current fitting causes the hose to butt up against the tall bottle that I got. Does anyone know what size or type fittings those are, or if it's possible to get a 90 degree fitting?
You can kind of see the issue in this pic... I actually had to slide the welder way forward and angle it, to even come close to clearing that hose.
Gotcha. I just wasn't sure if it was a special type of fitting with weird threads, since it holds gas. Didn't want to get something that seems to 'fit' but ruins the threads and leaks.Last edited by JGood; 01-10-2012, 10:22 PM.Comment
Don't change the color! Repaint it in the original beige.Comment
