The complete repair, rebuild, repaint, and v8 swap of my early model sedan
  • JGood
    • Jan 2004
    • 7959
    #901
    Mishimoto radiator #2 just dumped it's guts as I arrived at work today. The original one lasted 1 year/10k miles. The warranty replacement lasted almost an identical amount of time/miles. I'm going to give it one more shot, but if it happens again in this short of a time period, I'm going another route.
    Also had to get towed home from bimmerfest a few weeks ago. The car stalled as I was leaving the parking lot and wouldn't restart. The main relay wasn't clicking, but I didn't have a multimeter with me to troubleshoot. Turned out to be the fusable link on the DME power wire. I spliced in a generic inline fuse housing that uses normal 1/4" fuses, and now have a 5 pack of 30 amp fuses in the glovebox, so no more worries.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • The Dark Side of Will
      • Jun 2010
      • 2796
      #902
      Any idea *why* it blew the fuse?
      • JGood
        • Jan 2004
        • 7959
        #903
        I don't think it 'blew', I think it just corroded to the point where it was too thin to handle the load of the DME. It's not uncommon on a 30 year old, 315k mile car. The part of the thin metal strip that was left behind looked corroded too. I also had a trunk full of crap, something could have given it the final blow while I was accelerating out of the parking lot.
        The factory fuse was a 50amp, I replaced it with a 30amp, and have yet to have an issue, so I don't think it was a short or overload.
          • Jun 2010
          • 2796
          #904
          True dat, makes sense. Fusible links are terrible ideas, but saved BWM .50 DM or something.
          • JGood
            • Jan 2004
            • 7959
            #905
            They could have at least put it somewhere safer then the middle of the trunk. Could have been incorporated into the junction on the firewall, that would have been nice and easy to access/repair. Then again, I think e30's do come with a hard plastic cover for the cable in the trunk, which mine no longer has. Suppose I should pick one of those up to protect my new fuse...
            • Denny
              • Jan 2010
              • 822
              #906
              Originally posted by JGood
              Went to the drag strip the other night.
              2820lbs without me, but with 3/4 tank of gas, the spare tire, and my normal crate of tools/supplies in the trunk. Basically, the way I drive it 99% of the time.
              Best time was as follows:
              60' ...... 2.018
              330 ..... 5.592
              1/8 ..... 8.505
              MPH .... 83.01
              1000 ... 10.996
              ET ...... 13.099
              MPH ... 107.21
              All of my runs were 13.1-13.3, 107-108 mph. Didn't hook up in any of them. I've done a 1.9 60' before in this car, just couldn't do it again that night. I guess the additional low end torque makes it more difficult. If I can do that again, I'll be in the 12's. But I'm VERY happy about the trap speed increase. From 102-103 with the m60b40, to 107-108 with the m60b44. That shows that there is a serious power gain. I'm probably near 300whp. e39 M5's with good drivers usually end up with very similar ET/MPH numbers, so I'd expect I'd be about even with one until probably 130ish or so, when their peak power and aerodynamics take over.
              Exactly the amount of power I'm looking for... Awesome numbers for a full street car with N/A power. Anymore then this and its a new world of SNAP action not clutches slipping but in like Axles snapping. With my Twincharged setup at its almost lowest power setup I was making over 400 pounds of torque...sold the setup it was getting too expensive..v8 is taking its place its a great compromise between a M30B35 swap and all out Boost power.
              Denny
              ___________
              1990 BMW red 325IC M30B35 all stock Girlfriends ride
              1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
              Blogs:
              http://bmw325e30.blogspot.com/ (restoration)
              http://bmw325e30turbo.blogspot.com (Twincharge M20)
              http://bmw325e30m62b44.blogspot.ca/
              • DER E30
                • Sep 2013
                • 2343
                #907
                If you think about it, putting the fuse right near the battery is probably safer than in the engine bay because the length of wire that isn't fused is much shorter. Having fuse protected wire in the entire car makes sense then. My buddy almost lit his car on fire with a 00 welding cable for his amp that had no fuse! The wire rubbed the insolation off and it arced off the frame.
                Love your car! The color is awesome! And that v8!
                -Christian
                • JGood
                  • Jan 2004
                  • 7959
                  #908
                  Well the main thick battery cable isn't fused. There's a smaller 14 gauge wire that runs parallel to it for the DME that is fused. It's literally taped right to the main power wire. I guess it's not a big deal either way, most e30's make it to their grave without that fuse ever being seen.
                  Thank you!
                    • Jun 2010
                    • 2796
                    #909
                    Obviously the main wire from the battery to the starter is unfused and VERY rarely has any problems, across the entire auto industry. It's just run more intelligently and protected much better than most guys who run unfused power to their amps...
                    • Jean
                      • 18228
                      #910
                      JGood good numbers man!
                      • JGood
                        • Jan 2004
                        • 7959
                        #911
                        Destroyed another axle, so it looks like I'm going to be picking up a set of the CA Tuned chromoly axles. The price for a pair is the same cost as a single OE axle, so it's a no-brainer.
                        I'm wondering if the design of the diff naturally puts more power to the drivers side wheel. I've had a total of 3 axles on that side, and they've all twisted the splines. Neither of my passenger side axles have done that.
                          • Jun 2010
                          • 2796
                          #912
                          Longitudinal torque reaction from the engine and trans twisting can load the suspension asymmetrically... it usually only affects live axle cars, though.
                          Do you have urethane or rubber subframe bushings?
                          • GunMetalGrey
                            • Dec 2010
                            • 1499
                            #913
                            If you do get a set of the CA Tuned axles make sure to post up about them! My half shafts fear the m50 turbo that powers them and if the CA tuned ones hold up they may be on my upgrade list.
                            • JGood
                              • Jan 2004
                              • 7959
                              #914
                              Urethane, but they were only installed after I twisted 2 axles. So it did it both with stock rubber and urethane. T/A bushings are new rubber. 650lb springs/Bilstein Sports back there as well, there isn't a ton of movement.
                              • JGood
                                • Jan 2004
                                • 7959
                                #915
                                That's why I've yet to take the plunge. They almost seem too cheaply priced, compared to other beefy e30 axles. I'd really like some customer feedback first. I mean even if they're equal in quality/strength to OE, they are still 1/2 the price, and according to my local dealer there are currently no axles in the US, and the wait time is 2+ weeks...
