The complete repair, rebuild, repaint, and v8 swap of my early model sedan
  • GunMetalGrey
    • Dec 2010
    • 1499
    #916
    I would shoot them an email or call and ask more about them, or how much they will stand behind them. If they are willing to offer a refund if you twist one then you can't lose!
    If I needed halfshafts at this point I would give them a go, but mine are not an issue at 7psi. When I get my clutch broken in and it sees 16+ psi it will be a different story.
    • slammin.e28
      שמע ישראל
      • 12054
      #917
      I think you just need to find a way to reduce some of that power.
      • JGood
        • Jan 2004
        • 7959
        #918
        Like delay my build for 3 years? :p
        e30 restoration and V8 swap
        24 Hours of Lemons e30 build
        • slammin.e28
          שמע ישראל
          • 12054
          #919
          I don't have any broken axles.....
          ....jussayin..... :p
          • JGood
            • Jan 2004
            • 7959
            #920
            Sent an email to CA Tuned about the axles. I asked about who makes them, what the warranty is, what parts of the axles are upgraded (CV joint parts, etc...) Response:
            They are made by us in house. We got tired of braking them with pushing over 500 pounds of tq.
            So these have been tested for over a year with no issues. The rating on them is over 700hp.
            Everything that is possible to upgrade we have upgraded it.
            Let us know if you need anything else.
            First year is a full replacement. FREE
            Second year is 15% replacement cost
            3rd year and on: 30% replacement cost
            I'm going to pick a set up shortly. Can't beat that warranty IMO. If they last 3 years and then break, and I need to pay $150 for a brand new set of axles, I certainly won't cry.
            • JGood
              • Jan 2004
              • 7959
              #921
              You don't have any fun either!
              (...fun defined in this case as v8 e30 burnouts)
              • GunMetalGrey
                • Dec 2010
                • 1499
                #922
                Why do people still insist on HP ratings? It's torque that kills!
                Regardless it sounds like they will back up their product very well, and I will be picking up a set when I turn up the boost!
                Thanks for emailing them!
                And like you said, even if they do break after three years, $150 is most certainly worth 3 years of axle abuse!
                • bradnic
                  • Jul 2012
                  • 3550
                  #923
                  ...I'm going to be picking up a set of the CA Tuned chromoly axles. The price for a pair is the same cost as a single OE axle, so it's a no-brainer.
                  Yeah they're $480 a pair.. total no brainer! thanks for the heads up
                  HOWTOs:
                  DB vert plastic bumpers
                  OEM Keys
                  MTech1 docs
                  88 ix Lach/Card
                  91 ic Calypso 3.1
                  86 Cosmo 2.7
                  OEM+ or bust!
                    • 37828
                    #924
                    Maybe an Eta swap?!
                    Classic BMW Specialists
                    Grover Beach, CA
                    www.BimmerHeads.com
                    • JGood
                      • Jan 2004
                      • 7959
                      #925
                      Mishimoto radiator #4 is set to arrive tomorrow. This one was free of charge, with free 2nd day air shipping. Hard to beat their customer service.
                      #3 arrived a few days ago with a defective overflow nipple. Stripped threads and angled to the point where I couldn't get the hose installed.
                      Once I receive the new one, I'll weld the overflow hole on #3 shut and either drill & tap a new hole or weld a bung on somewhere for a new barb, and keep it as a spare.
                      My recommendation to anyone buying these radiators is to immediately replace the plugs with higher quality stuff. They seem to use a very porous, cheap, cast aluminum for the nipple, temp sensor plug, and drain plug. They almost feel like plastic.
                      • ThatOneEuroE30
                        • Dec 2013
                        • 8626
                        #926
                        Which mishimotos are you buying. I haven't had problems with mine
                        1991 318i 4dr slick top
                        Mtech 2 turbo restoration
                        • JGood
                          • Jan 2004
                          • 7959
                          #927
                          The big 3-core Z3M. The cores started leaking after 1 year/10k miles on the first two.
                          • ThatOneEuroE30
                            • Dec 2013
                            • 8626
                            #928
                            O i got the regular 2 core e36 haven't had a problem
                            • AndrewBird
                              The Mad Scientist
                              • 11898
                              #929
                              The E36 Mishimoto I put in my E34 recently started leaking after about a year. $30 in shipping for a new one, but I have yet to install it.
                              • ThatOneEuroE30
                                • Dec 2013
                                • 8626
                                #930
                                Is yours leaking at the plugs to?
