Kamotors E30-Turbo to ITB M20
  • AWDBOB
    • Aug 2013
    • 4386
    #1681
    You would be forever grateful if you stopped using open scroll housings and went TS.
    • TrentW
      • 2815
      #1682
      What caused it to overheat so severely to crack the block?
      • LJ851
        • 7918
        #1683
        It's not necessarily overheat, the deck on B35 engines is thin and the load from the head studs can crack it. B34 blocks have more meat there.
        Lorin
        The M30 is God's engine.
        • TrentW
          • 2815
          #1684
          He was referring to the M20 though.
          • RagtopE30
            • Dec 2010
            • 1869
            #1685
            You will LOVE the removable radiator support once you start trying to fit the M30 in there! Good move
            450whp 524 lb-ft 1988 336ic In progress
            http://www.r3vlimited.com/board/showthread.php?t=250709
            • LJ851
              • 7918
              #1686
              Originally posted by kamotors
              sooo big issue. Block has about 5 cracks. need a new block.
              also cylinder is coolant washed.
              got a crack free block and machined crank from Titan Omega. Can finally start putting the M30 together.
              you can see why im doing the m30 swap now, m20s block has been cracked for over a year now due to a pretty bad overheat last year
              All this talk about cracks got me mixed up. Cracks, Cracks everywhere !
              Lorin
              • kamotors
                • Nov 2007
                • 7102
                #1687
                m20 and m30 blocks are cracked.
                for the m20 I was traveling at a speed that I shouldn't post @23psi and went around 3 miles without coolant after a headgasket blew.
                7speedshop.com
                • ThatOneEuroE30
                  • Dec 2013
                  • 8626
                  #1688
                  Lol 150+
                  1991 318i 4dr slick top
                  Mtech 2 turbo restoration
                  • TrentW
                    • 2815
                    #1689
                    Well...that explains it.
                    • TheTacoMan
                      • Nov 2011
                      • 2308
                      #1690
                      Lol 150+
                      I was there, it was the best pull ever.
                      • ThatOneEuroE30
                        • Dec 2013
                        • 8626
                        #1691
                        I could probably imagine. 23psi pull that blows a block would have to be a wicked ass pull.
                        • kamotors
                          • Nov 2007
                          • 7102
                          #1692
                          got some more done today.
                          stripped out a bit of sound deadening to make some more room for everything.
                          where the rad support mounts(will be using different hardware)
                          clearance for a bigger intercooler as well you can see I made it so teh upper half slide around the lower half which makes it really sturdy.
                          couple hours later and its done and looks better than before.
                          7speedshop.com
                          • ThatOneEuroE30
                            • Dec 2013
                            • 8626
                            #1693
                            You going to be using a mishimoto rad?
                            • kamotors
                              • Nov 2007
                              • 7102
                              #1694
                              depends on whats left of my budget
                              7speedshop.com
                              • Bimmer_man
                                • Jan 2013
                                • 1477
                                #1695
                                Dang man you work fast. What radiator are you going to get?
                                Float like a cadillac sting like a Bimmer!:)
