Kamotors E30-Turbo to ITB M20
  • Jb325is
    • 2137
    #1771
    Yep. As long as it's a 4 bolt you are good. I used e28 front, e30 rear on mine
    - '88 m54 coupe
    <3
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      #1772
      Originally posted by kamotors
      what, listing is only for $199?
      When I hitte eBay add it said 449 maybe that's with everything else he has for sale
      1991 318i 4dr slick top
      Mtech 2 turbo restoration
      • kamotors
        • Nov 2007
        • 7102
        #1773
        wait why cant I just use this swap guibo that converts from the 96mm/12mm ZF transmission flange to the 78mm/10mm E30 driveshaft?
        that way I keep my nice perfect condition driveshaft, save money, and get a nice guibo.
        7speedshop.com
          • 37834
          #1774
          That would work too! Good way to test the quality of Revshift's stuff too.
          Grover Beach, California
          BimmerHeads.com
          • Jb325is
            • 2137
            #1775
            A friend of mine tried to use one of these and it either didn't fit or fell apart, maybe both. I can't remember though
            - '88 m54 coupe
            <3
            • Good & Tight
              • Apr 2004
              • 2057
              #1776
              Something to consider
              you'll end up twisting the drive shaft with that guibo. You need some kind of flex in the drivetrain.
              I ran the one with red urethane bushings, which were hard. If the blue ones are softer that might help. Mine would twist at the splines, went through two driveshafts then switched back to a stock one.
              Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
              ____________________________
              E-mail Panayiotisx2@gmail.com
              Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
              • FLG
                • Sep 2011
                • 3165
                #1777
                Yep I'd not run the solid guibo either.
                Sent from my SCH-I545 using Tapatalk 2
                -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                • TheTacoMan
                  • Nov 2011
                  • 2308
                  #1778
                  Ive been running a solid guibo for a couple months with no problems with stickey tires and some hp, last driveshaft however did have a crazy amount of play in the u-joints.
                  • adonwilson
                    • Mar 2012
                    • 314
                    #1779
                    I just installed a 328i DS and m3 guibo with my ZF swap...
                    • Good & Tight
                      • Apr 2004
                      • 2057
                      #1780
                      Revshifts guibo is a strong piece, no doubt. Survived countless launches with over 600ftlbs to the wheels. With an after market driveshaft it would make sense, but with a stock DS and the torque a turbo M30 makes the DS will fail.
                      • TheTacoMan
                        • Nov 2011
                        • 2308
                        #1781
                        I think even the m20 fried my last driveshaft and is probably slowing killing the one I have right now. I got mine for 30$ from a buddy is my reason for running it, a one piece driveshaft would be nice..... One day.
                        • kamotors
                          • Nov 2007
                          • 7102
                          #1782
                          I'm going to give the revshift guibo a shot as a temporary solution, then go with a good used driveshaft once I find one.
                          also going with a precision 6266 t4 turbo
                          Compressor Wheel Inducer: 62mm
                          Exhaust Housing A/R: 1.15
                          Exhaust Housing Inlet: T4 Divided - "Twin Scroll"
                          Exhaust Housing Outlet: V-Band
                          Compressor Housing: "SP" - 4.0"/2.5" Ported Shroud
                          Bearing Type: Journal Bearing
                          HP Rating: 735
                          and
                          Precision 46mm wastegate
                          7speedshop.com
                          • Lof8
                            • Oct 2006
                            • 2827
                            #1783
                            You've taken this car a long way. It looks awesome!
                            S50'd
                            Originally posted by TDE30
                            What is this faggy shit I have happened upon?
                            I can always live in a M3. Can't M3 a house.
                            • kamotors
                              • Nov 2007
                              • 7102
                              #1784
                              clutch comes tomorrow so might as well drop it in this weekend.
                              7speedshop.com
                              • ak-
                                • 12422
                                #1785
                                Man, that's quite a big exhaust side.
                                1991 325iS turbo
