Wow, sucks about spec. I was hoping to see an update with that beast finally running but nothing but more clutch bs. Hope it gets sorted and you can get back to punishing tires!!
Kamotors E30-Turbo to ITB M20
This is for the E12/E28 M30, from what I know all early clutch/trans can go in late but not all late can go into the earlier. Hope this helps...
Just checked VAC because I thought I remembered them carrying one and its the same, only the FX300:
http://store.vacmotorsports.com/clut...kit-p2481.aspx
Judging by a 110% increase in holding capacity it should be good to roughly 420whp by my calculations1990 325i Touring - The Bonsai Bimmer - Patiently Waiting
1984 316 Coupe - The Base Model - Pain in the Ass
1988 750iL - The Daily Driver
...And a couple others...Comment
Yeah doesn't look like they make them though :( Are you trying to go exclusively through ultrarev? If not maybe check out clutch net I'm sure that their stage 5 will hold plenty1990 325i Touring - The Bonsai Bimmer - Patiently Waiting
So you got 2 bad clutches, paid $800, and they don't have a response? How can they run a business like that. They should refund your money or send you a good clutch free of charge at the LEAST.
20 year old custom M10 flywheel with 7.25" twin disc, rated for 900ftlbs.
When your making big torque you need to choose carefully, pulling the tranny in and out 1/2 dozen times or more because some piece of shit lying clutch manufacturer is not cool.
Kam patience brother.......you'll get it sorted.Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
____________________________
E-mail Panayiotisx2@gmail.com
Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=ULComment
And that's why when the clutch time comes I'm getting YOUR clutch specs.Comment
Just go with Otis setup you'll know it work.Comment
otis has a C4 behind him m30......you could go with his old setup, but its on a buddies car.
Edit: I see he's already talking about his old setup. Brandon, mike has that in his e28 now.sigpic
Instagram @rebellionforgeComment
e34 M5 stuff should work
