Kamotors E30-Turbo to ITB M20
    7speedshop.com
      Congrats! Glad to see it all come together for yah. It is a good feeling isn't it?
      Are Three Vee
      Dad Spec
        its a great feeling, I love this car:)
        7speedshop.com
          Though I personally wouldn't build or even buy an auto car, the work you've put in, and the result is amazing!
          Go here be happy!
          Ratchet Garage e30 V8 build.
            Got mine back on the road today as well. Nothing beats a well running boosted e30 :)
            1987 325i-M60b44 swap
              good job^
              7speedshop.com
                Great news about the car running well!
                I hope you post some more vids in the future.
                  Going to try some form of 2 step Launch Control. Just going to see how ridiculous I can make my automatic transmission E30. Going to see what I can get my stall to first and probably going to do a high stall converter. I'm having way too much fun with this little automatic.:)
                  video of automatic 2 step.
                  http://www.youtube.com/watch?v=muoEA...layer_embedded
                  7speedshop.com
                    Just a little FYI, the forward clutches in the trans are stupid-easy to replace (once the trans is out) in case you ever need to do so.
                      so I got my bimmerworld 15mm rear spring pads and now My rubbing/squatting issues issues should be fixed.
                      7speedshop.com
                        What tires are you running on the trm c1's?
                          kuhmo ecsta 225/50
                          7speedshop.com
                            SO, I think I've made the final tune with the WAR chip. I had to do lots of work on the tuning map but its running really good now. my AFR is around 11.6 at WOT pulls and it feels good. I went all day with the car feeling excellent and then for some reason my bottom end leaned out a bit and I grew the rich spike back when my temp got to a bit above the 1/2 mark( I had my fan turned off because I was driving at higher speeds most of the time). I readjusted the fuel MAP a bit and hopefully it stays good.
                            7speedshop.com
                              Automatics can be fun, just got to have some power infront of them though :D
                              1992 BMW 325iC
                              1978 Chevrolet Monte Carlo
                                I 'm loving it, I can almost build 1 psi off the line from loading up the drive train with the gas pedal and brake pedal.
                                7speedshop.com
