Kamotors E30-Turbo to ITB M20
  • msb2tg
    • 38
    #3841
    OMG.. sweet set up!
    • MPLFoster
      • May 2013
      • 1490
      #3842
      Is there a dramatic difference in running ITB’s with FI?
      form.follows.function IG @mplfoster
      • LowR3V'in
        • 4209
        #3843
        ya, more throttle plates blocking airflow
        • kamotors
          • Nov 2007
          • 7102
          #3844
          So quickie update, running 10.5psi. Will get on the dyno before bimmerfest then move onto testing a slightly larger turbocharger. Have been beating on this car every single week without issue!
          7speedshop.com
          • vtechnik
            • Jan 2018
            • 379
            #3845
            I can't wait for dyno numbers, looks amazing as usual.
            1988 ~ Lacey ~ 325iS
            • CharlieVu
              • Jan 2018
              • 103
              #3846
              So awesome! I found it funny how on page one they were cracking on you for turboing your automatic transmission. Before I start searching for what happened, how did it hold up? I saw you converted to manual in the photos. I can’t wait to order the 20g kit, I had a fp20g on my bugeye wrx with a jdm 5 speed Sti tranny and boy must I say, no car has put a smile on my face since- until now. Just picked up my first e30 vert and am learning everything about it. Almost ordered the kit with my tax return last week but the wifey had other plans. Great build and I can’t wait!!
              • kamotors
                • Nov 2007
                • 7102
                #3847
                So the automatic ended up losing reverse when cold, and couldn't shift fast enough above 9psi, it would clip the limiter between shifts. Never slipped or anything but enough problems that a 5speed swap was in order. At 7psi the auto shifted well.
                7speedshop.com
                • CharlieVu
                  • Jan 2018
                  • 103
                  #3848
                  Ah good to know. Good thing I’m piecing my 5 speed swap together for this summer. Was hoping you had blown it up lol
                  • kamotors
                    • Nov 2007
                    • 7102
                    #3849
                    Quick update, car has been running flawless, no mechanical changes or maintance has been needed other than rear tires soon and oil change. Had some tune issues at radwood but got it all straightened out. Auto-xing on the itb turbo setup is a blast!
                    Sent from my SM-G950U using Tapatalk
                    7speedshop.com
                    • kamotors
                      • Nov 2007
                      • 7102
                      #3850
                      Oh and I finished building my 7 series for daily duty. Should be the only 750il in sepang bronze metallic. Started out as a prefacelift 98 750il.
                      7speedshop.com
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        #3851
                        5's and 7's so sweet.
                        john@m20guru.com
                        Links:
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          #3852
                          Hey, Cam yes you. Come by and verify your deal. Will split the Dyno cost, but........ I'm fairly certain thin regrind.
                          D's suck doo doo, but it's a 90% sure thj t..
                          And no, don't mind from aong time map ownrr
                          john@m20guru.com
                          Links:
                          • kamotors
                            • Nov 2007
                            • 7102
                            #3853
                            Wut...
                            7speedshop.com
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              #3854
                              Posted in wrong thread. :\
                              john@m20guru.com
                              Links:
                              • Powling
                                • Jan 2015
                                • 1290
                                #3855
                                Even then...wut?
                                Steve • Toronto
                                1991 318is • Brillantrot
                                Build Thread
