Kamotors E30-Turbo to ITB M20
  • kamotors
    • Nov 2007
    • 7102
    #376
    ran vac to the valve cover and it worked flawless! not even a hint of smoke, and maybe its in my head but the car seemed to idle better also.
    7speedshop.com
    • nokincy
      • Feb 2012
      • 302
      #377
      Nice build! When you eventually switch diffs I'll take the 4.27 off your hands. Just let me know when and I'll even cover shipping haha.
      • kamotors
        • Nov 2007
        • 7102
        #378
        made a more aggressive tune and its working excellent! Need to film some videos for you guys, its a completely different car on 11psi with the proper tune. Its a real tire smoker now but at the same time if your cautious you can really get it to hook up and go.
        7speedshop.com
        • ak-
          • 12422
          #379
          Why would you put the return bung right under one of the oil pan bolts lol
          1991 325iS turbo
          • kamotors
            • Nov 2007
            • 7102
            #380
            its 100% flat there and I can simply unscrew the bung to remove my pan..... how often do you need to remove a pan? just treat it as a 24mm bolt that needs to be removed to get the pan off, an extra 3 seconds to remove a pan isn't a big deal.
            7speedshop.com
            • ak-
              • 12422
              #381
              I thought you were WELDING a bung on there
              1991 325iS turbo
              • kamotors
                • Nov 2007
                • 7102
                #382
                sorry, I drilled and tapped
                7speedshop.com
                • theox69
                  • May 2008
                  • 1732
                  #383
                  Where did you get that awesome elbow coming off your turbo? I've been looking everywhere for those!
                  you can have the keys to my hunk of 20+ year old West German steel when you pry them from my cold dead fingers.
                  • kamotors
                    • Nov 2007
                    • 7102
                    #384
                    I made it!:D works great and is air tight
                    7speedshop.com
                    • BMWManiac
                      • Dec 2010
                      • 1091
                      #385
                      Great build, can't wait to boost my E30!
                      1997 Artic Silver M3
                      CES GT4094r 651hp/615tq @ 24 psi
                      • kamotors
                        • Nov 2007
                        • 7102
                        #386
                        safely made it to 12psi. I have enough fuel for 12.0- 12.4AFR under WOT.
                        I can run 0-60 in under 5 seconds and my top speed is just about 125mph at 6100rpms.
                        7speedshop.com
                        • Sagaris
                          • Sep 2009
                          • 2243
                          #387
                          NICE WORK! You definitely need to make some more videos. Are you running into traction issues? how is the lag?
                          • kamotors
                            • Nov 2007
                            • 7102
                            #388
                            Yes I do; and I just got a new camera:)
                            traction is only an issue going into second gear if its a straight line. If there is ANY curve in the road you will get sideways if you aren't careful. Honestly, lag is not noticeable at all with my gearing, I'm rarely below 2.5K and by 3krpms I have full boost. It is very peppy and boost hits VERY hard:)
                            7speedshop.com
                              • 37828
                              #389
                              No issues with the plug wires getting too hot? I just put some DEI fire sleeve stuff on mine.
                              Classic BMW Specialists
                              Grover Beach, CA
                              www.BimmerHeads.com
                              • kamotors
                                • Nov 2007
                                • 7102
                                #390
                                no issues, my turbo blanket works perfect,I can touch the blanket right after a drive and its never hotter than the valve cover
                                7speedshop.com
