Kamotors E30-Turbo to ITB M20
  • kamotors
    • Nov 2007
    • 7102
    #601
    Also going to start some weight reduction now. Going to make custom bumper beams to get rid of the current heavy fiberglass cores
    7speedshop.com
    • Denny
      • Jan 2010
      • 822
      #602
      Originally posted by sayed ali
      Boost is an addiction :)
      I think I found my new quote for my signature :) damn right!
      Originally posted by kamotors
      after I got my new tires it stopped being so crazy so I need more power to make it crazy again:)
      Damn man your car is a whole new beast now!! hows does 20PSI feel compared to your old 10-12 PSI WAR MAF setup.... How much timing can you rock at 20PSI? and whats your AFR right now?
      Denny
      ___________
      1990 BMW red 325IC M30B35 all stock Girlfriends ride
      1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
      Blogs:
      http://bmw325e30.blogspot.com/ (restoration)
      http://bmw325e30turbo.blogspot.com (Twincharge M20)
      http://bmw325e30m62b44.blogspot.ca/
      • kamotors
        • Nov 2007
        • 7102
        #603
        WAR chip feels like poo compared to megasquirt. When I had WAR it was always things like that sensors bad or its my draw through setup and lame excuses for why my car wouldn't run with stock like drive ability. For a moment I almost believed that it wasn't possible to drive like stock with a turbo. But then day I slapped on megasquirt...... even un-tuned the car ran perfect. Same sensors and everything worked with NO CEL so I could technically pass smog with a cat.
        20psi feels amazing, its a real rush to drive and will get yoy in trouble very quickly. Running around 22degrees of timing and 11.8 AFR. I want to try a few more degrees of timing but I feel I need 93 octane for that
        7speedshop.com
        • Denny
          • Jan 2010
          • 822
          #604
          cool! I would need to get my temps in check with my SC to do 22 degrees but I got a big front mount coming for my twincharge setup..so I should be close to be able to use 22 degree if not W/M injection time :)
          When you can show me your fuel map.. and also how did you configure your injectors in MS...am moving from 30# to 60#?
          Denny
          ___________
          Blogs:
          • kamotors
            • Nov 2007
            • 7102
            #605
            Considering fender flares, like zg style so I can go wider right now I'm noticing a lot of rubber dust building up on my rolled flat flares from rubbing every now and then. I actually took a good mm out of one of my rear tire because it caught the fender lip while sliding a turn, it ended the drift pretty quickly..... I can not even fit a finger in my front fender gap. Before I rolled it on the new wheels the car wouldnt even move and a note card could be held by my fender gap.
            thinking like this.
            7speedshop.com
            • Denny
              • Jan 2010
              • 822
              #606
              thinking like this.
              Very cool! let me know how much they cost $$$ I may be interested too. I'm going to need 245's in the back minimum:twisted:
              Denny
              ___________
              Blogs:
              • kamotors
                • Nov 2007
                • 7102
                #607
                They are usually less than $200, problem I'm having is that most are only 2" flares and I would need about 3" to have room for something like superwide 245's or 265's
                7speedshop.com
                • FLG
                  • Sep 2011
                  • 3165
                  #608
                  What fuel pump are you using? Had to cut my dyno tune short at 14psi because anything more the fuel pump couldn't keep up
                  Sent from my Galaxy Nexus using Tapatalk 2
                  -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                  • 325ix
                    • Aug 2009
                    • 7783
                    #609
                    Those flares look pretty good. I can't get a finger between my rear fender and tire, the fender has rubbed all of the sidewall writing off but, that's because the fenders were never rolled.
                    • kamotors
                      • Nov 2007
                      • 7102
                      #610
                      still on stock fuel pump with no fueling issues.
                      my flares are very rolled and still rub:( the front are rolled 100% flat and pulled 2-3mm and I still get rub, my tires are bulging off of an 8" rim
                      7speedshop.com
                      • FLG
                        • Sep 2011
                        • 3165
                        #611
                        Guess my fp is just not up to the task.
                        • kamotors
                          • Nov 2007
                          • 7102
                          #612
                          so fender flares are on the way, Going to do some custom work to make them look good on the E30
                          7speedshop.com
                          • Denny
                            • Jan 2010
                            • 822
                            #613
                            Watching very closely :) I'm going to need these...
                            What size tires are you going to use?
                            for my rears 16x9 I wanted to go 245/45/16 but its ridiculous expensive and 245/50/16 are just to BIG overall..
                            Denny
                            ___________
                            Blogs:
                            • kamotors
                              • Nov 2007
                              • 7102
                              #614
                              my current tires actually about as wide as some 245's. looking to get some 17x9 OZ superleggeras with 265 for the rear keep current tire up front.
                              they are basically the beastly version of my current wheels
                              Also decided to try out brake boosting yesterday while cruising. its insane, I can build 10psi while rolling at about 40-50mph, I let off the brake my tires screech and i fly away lol, insta boost
                              also IF the flares turn out good I'm willing to modify other sets to be E30 specific and sell them at a MUCH cheaper price than any other E30 flare out there.
                              7speedshop.com
                              • FLG
                                • Sep 2011
                                • 3165
                                #615
                                What company?
