Also going to start some weight reduction now. Going to make custom bumper beams to get rid of the current heavy fiberglass cores
Kamotors E30-Turbo to ITB M20
Originally posted by sayed ali View PostBoost is an addiction :)
Originally posted by kamotors View Postafter I got my new tires it stopped being so crazy so I need more power to make it crazy again:)Denny
___________
1990 BMW red 325IC M30B35 all stock Girlfriends ride
1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
Blogs:
http://bmw325e30.blogspot.com/ (restoration)
http://bmw325e30turbo.blogspot.com (Twincharge M20)
http://bmw325e30m62b44.blogspot.ca/
Originally posted by Denny View PostI think I found my new quote for my signature :) damn right!
Damn man your car is a whole new beast now!! hows does 20PSI feel compared to your old 10-12 PSI WAR MAF setup.... How much timing can you rock at 20PSI? and whats your AFR right now?
20psi feels amazing, its a real rush to drive and will get yoy in trouble very quickly. Running around 22degrees of timing and 11.8 AFR. I want to try a few more degrees of timing but I feel I need 93 octane for that
7speedshop.com
Originally posted by kamotors View PostWAR chip feels like poo compared to megasquirt. When I had WAR it was always things like that sensors bad or its my draw through setup and lame excuses for why my car wouldn't run with stock like drive ability. For a moment I almost believed that it wasn't possible to drive like stock with a turbo. But then day I slapped on megasquirt...... even un-tuned the car ran perfect. Same sensors and everything worked with NO CEL so I could technically pass smog with a cat.
When you can show me your fuel map.. and also how did you configure your injectors in MS...am moving from 30# to 60#?Denny
___________
Blogs:
Considering fender flares, like zg style so I can go wider right now I'm noticing a lot of rubber dust building up on my rolled flat flares from rubbing every now and then. I actually took a good mm out of one of my rear tire because it caught the fender lip while sliding a turn, it ended the drift pretty quickly..... I can not even fit a finger in my front fender gap. Before I rolled it on the new wheels the car wouldnt even move and a note card could be held by my fender gap.
thinking like this.
7speedshop.com
Originally posted by kamotors View PostConsidering fender flares, like zg style so I can go wider right now I'm noticing a lot of rubber dust building up on my rolled flat flares from rubbing every now and then. I actually took a good mm out of one of my rear tire because it caught the fender lip while sliding a turn, it ended the drift pretty quickly..... I can not even fit a finger in my front fender gap. Before I rolled it on the new wheels the car wouldnt even move and a note card could be held by my fender gap.
thinking like this.
Very cool! let me know how much they cost $$$ I may be interested too. I'm going to need 245's in the back minimum:twisted:Denny
___________
Blogs:
Originally posted by Denny View PostVery cool! let me know how much they cost $$$ I may be interested too. I'm going to need 245's in the back minimum:twisted:
They are usually less than $200, problem I'm having is that most are only 2" flares and I would need about 3" to have room for something like superwide 245's or 265's
7speedshop.com
Originally posted by FLG View PostWhat fuel pump are you using? Had to cut my dyno tune short at 14psi because anything more the fuel pump couldn't keep up
Sent from my Galaxy Nexus using Tapatalk 2
Originally posted by 325ix View PostThose flares look pretty good. I can't get a finger between my rear fender and tire, the fender has rubbed all of the sidewall writing off but, that's because the fenders were never rolled.
7speedshop.com
Watching very closely :) I'm going to need these...
What size tires are you going to use?
for my rears 16x9 I wanted to go 245/45/16 but its ridiculous expensive and 245/50/16 are just to BIG overall..Denny
___________
Blogs:
Originally posted by Denny View PostWatching very closely :) I'm going to need these...
they are basically the beastly version of my current wheels
Also decided to try out brake boosting yesterday while cruising. its insane, I can build 10psi while rolling at about 40-50mph, I let off the brake my tires screech and i fly away lol, insta boost
also IF the flares turn out good I'm willing to modify other sets to be E30 specific and sell them at a MUCH cheaper price than any other E30 flare out there.
7speedshop.com
