How did you install the injector for your meth? Just thread it in like they say or did you use a jb weld or something to set it in? Im skeptical about just threading it into the charge pipe..
Kamotors E30-Turbo to ITB M20
Originally posted by MF DOOM View PostHow did you install the injector for your meth? Just thread it in like they say or did you use a jb weld or something to set it in? Im skeptical about just threading it into the charge pipe..
Ive had some experience with this and Iat sensors.
This thing has to be a beast to drive///sigpic
1986 "C2 2.7 Alpina" Sedan
1987 325ic Black Vert
car needs a valve adjustment again, its needed one every 1k miles lol, too much revlimiting,2 step and revving to 7300rpms daily. Then I'll probably get it up to 18psi and see how it performs. Its usually just one or 2 that get knocked out of adjustment but this time they are all pretty loose.
7speedshop.com
Originally posted by kamotors View Postsome fall photos
Nice pics, if you have any close ups send them to condorspeedshop@gmail.com to be considered for next years 2014 calendar.
•• Powersteering Deletes • M20 Motor & Trans Mounts • 24V swap mounts • UHMW Offset CABs ••
•• Rear Subframe Bushings • RTABs • Facebook ••
Car is running awesome, some big things happening soon, you'll see it on youtube in about 1 month.
Rear window tint removed which took 3 days, completely detailed the interior, replacing the windshield later this week. Installed the 3.73LSD which has a few issues but seems to be working now also cranked up the boost to 19psi which is amazing.
7speedshop.com
lots of WOT tuning today. Did 7 virtual dyno/datalogs-retunes, all which resulted in a better AFR but consistently dropped in power, noticed it was heat soak. Finally got the AFR dialed in and its feeling great.
new timing map,fuel map, Baro correction dialed in better, MAT correction dialed in, and smoothed out the lumpy idle a bit.Last edited by kamotors; 11-01-2013, 07:53 PM.
7speedshop.com
well some somewhat not good news.
*Rear diff groans on tight turns with clutch out.
*replaced windshield and they messed up my paint and the new gasket, but i guess its better than a huge crack.
* rock hit turn signal cover cracking it, and burning out bulb, replaced bulb and it still wont work, its all plugged in as well.
7speedshop.com
