316 superlite
  • petrolhead
    • 421
    #151
    Final contact pattern was something like this, on the "acceleration"(?) side:
    -coast side:
    -Not the best pic nor the clearest contact marks I know :D
    Final backlash, on the tight side but oh what the hell.. video: http://petrolhead.kuvat.fi/kuvat/198...330_165958.mp4
    Some of the stuff that got replaced
    Slip torque is now ~140Nm, whereas on a stock 25% LSD it's something like 40-50Nm.
    -that note says "NO OIL! FILL UP THE OIL!" :D
    • Nisse Järnet
      • Aug 2013
      • 1221
      #152
      Originally posted by petrolhead
      Front pinion bearing must be pressed/pulled out to replace the crush sleeve. And for that, the ring gear/LSD unit needs to come out, but that isn't a big job.
      A note on replacing shaft seals. They have a steel spring or ring around inner seal lip. I tried to rather press the seals in rather than hammer them on, so the small rings won't fly off.
      Ok damn :P
      I will try to just swap it and see how it feels :)
      E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
      E30 M50 6 spd 764whp @ 24psi.
      E30 M20 6 spd 675whp.
      • petrolhead
        • 421
        #153
        Rear end
        After some creative pause, I started work on the rear axle carrier..
        Set it up level:
        ..check if the mounting points are where they're supposed to be
        -straighten as neccessary or atleast try :)
        Attempted reinforcement welds where the factory welds looked insufficient:
        ..I used the angle gauge to also check the adjustment bits whatdoyoucallthem would be welded on in correct position:
        Nut interferes with the bushing top hat. But not if you flip the bolt the other way around, I learned. Ofcourse then the trailing arm can't be removed without dropping the whole axle carrier but who does that anyway :)
        Quick and careless sandblasting, then give it some wire brush & angle grinder, then a coat of epoxy primer:
        No it won't stay white.
        -Jarno
        ..edit:
        ..edit2: Tight fit with a flipped bolt, but no need to cut the bush top hat:
        • Sh3rpak!ng
          • Jan 2014
          • 2667
          #154
          Shadetree30
          • petrolhead
            • 421
            #155
            I disassembled the rear arms:
            Angle grinder, wire brush, sand blasting, acid..
            Epoxy primer paint
            Matte black spray can paint (3,90€ :) )
            Assemble everything with new stuff..
            • petrolhead
              • 421
              #156
              I bought a pair of Recaros.. They need new linings but that's a small problem. Only one of them in the pic. The other is torn gray :)
              Short video of the seat, how it works. Commentary is in elvish: http://petrolhead.kuvat.fi/kuvat/BMW...203_220403.3gp
              Rear axle, done!
              • petrolhead
                • 421
                #157
                • Bearmw
                  • 1323
                  #158
                  Hillarious man. I can so relate.
                  • petrolhead
                    • 421
                    #159
                    I compared a pair of E36 control arms to E30 items. The E36 ones move the wheel 4mm forwards, contrary to what I've read from various sources. I am sure about my measurements. Any thoughts about this? Is there supposed to be a difference between E36 M sport and non-M sport arms? I'm thinking mine might be M-sport ones :/..
                    -Jarno
                    Rear axle bolted to the car. Noticed that the pipes for parking brake cables I made, are too short and in wrong position.
                    • Ray Smoodiver
                      • Jun 2004
                      • 8809
                      #160
                      Port and Starboard control arms! A nice touch :grin:
                      • petrolhead
                        • 421
                        #161
                        I originally marked the diff bearing caps and shims to the casing like that so I won't mix them up. Then I saw similar color coding left/right on a Le Mans racer and got all excited :)
                        E36 (M-sport?) control arms with eccentric M3 bushes and new joints. Bushes move the wheel 2cm forwards, and the arms move it about 4-5mm. In all, quite a bit. Change in caster angle and caster trail should be noticeable. I even calculated how much it affects weight distribution :D, by ~1% or so.
                        Sway bar links will be M3-style for all the obvious reasons:
                        • petrolhead
                          • 421
                          #162
                          I spent a fair amount of hours investigating what kind bump steer I get with my front end setup. I actually got some useful results and I was able to make it more neutral . Now I believeI can fine tune it and I know how to change it if the need arises in the future.
                          Height to which the steering rack is installed seemed to be the most critical. I tried with shims between tierod inner end and rack, but that seemed like no big deal even when you have steering angle. If anyone else has measured these I'd be very interested to learn.
                          Jarno
                          • petrolhead
                            • 421
                            #163
                            Bit of angle grinder, acid, wire brush & sand blasting for the front struts:
                            Painted. Sort of.
                            Below is a comparison pic, 1966 2 liter block vs. 1983 318i block. I took rough measurements of cylinder wall thicknesses, the old block has about 1mm thicker. It's also missing a few coolant holes off the deck. Not worried about that, just makes it stronger.
                            • petrolhead
                              • 421
                              #164
                              I just came to tell you I ordered a set of 11,8:1 comp Wössner pistons. So the front of the car will be 1,6kg lighter :D
                              • kid325e
                                • Sep 2007
                                • 6422
                                #165
                                This is a sick build. I love the two colored sides of the suspension components, not so much for the aesthetic appeal but because it's a race car thing. We want pics of the pistons!
                                clutchCTRL!
                                Move with a purpose.
                                - 1991 325iX 4dr/5spd
                                - 2000 323i AT
                                2016 Mazda CX3 Sport AWD
