Gahhh i'm so jelly
Alpina B6 3.5 Turbo Tribute
Raul.. can you find out from what B10 BT this manifold is from ??
i like to know from what car ???Sveinbjörn Hrafnsson
E30 CABRIO V12 M70B50 ///
ALPINA B10 BITURBO 346 @ 507
E34 550 V12 JML
Finnish wisdom : If you want to Win,, hire a Finn
http://alpina.123.is/pictures/Comment
Simon
Current Cars:
-1966 Lotus Elan
-1986 German Car
-2006 Volkswagen Jetta TDI
Make R3V Great Again -2020Comment
I going to be jelly when you paint your car.
I will try to look up the email.
It looks like my old car. They changed the wheels on the 345i.
Here is what it looked like before the wheels were changed up.
Images for Mike Dietel 345i Alpina
Mike Dietel wanted to use US big bumpers to market his wide body kit. It was a original 1982 323i e21.Projects Hartge,Alpina & AC Schnitzer Builds.http://www.r3vlimited.com/board/showthread.php?t=280601
DSC04926 by Raul Salinas, on Flickr
DSC03413 by Raul Salinas, on Flickr
You can be jelly of my paint I'll still be jelly of every car your building hahaComment
It is mechanical injection and there is just a nozzle at the end of the tube at that cross bar in the venturi and sprays down the throat above the throttle plate.
They do the same with electronic injection as well, you can search for stand off injection and should find examples.Comment
Got it, thank you. I didn't know what term to search.It is mechanical injection and there is just a nozzle at the end of the tube at that cross bar in the venturi and sprays down the throat above the throttle plate.
They do the same with electronic injection as well, you can search for stand off injection and should find examples.I Timothy 2:1-2Comment
I did a little work on it lately. Today Frank and I were checking out the Alpina intakes. Just wanted to compare the differences. I am going to try both them out. Once the car is running.
I also pulled out my my Alpina vent gauge censers out to check them out. The one with the rubber boot on the left is the oil pressure the came with the Alpina vent gauge. The ones on the right I bought over the years. I am going to order oil cooler housing for a e34 m5 and a BMP design cap. It will allow me to use more than one censers.
I installed a KN air filter on my m30 valve cover.
DSC04013 by m3raul, on Flickr
DSC04014 by m3raul, on Flickr
DSC04031 by m3raul, on Flickr
E34 550 V12 JML
Slow progression is better then none!Comment
