Originally posted by OniKyan
View Post
The Legend of Ron Burgundrot.
Nah, not really. I just don't know how to go about making the linkage between the carbs. Two sets of 41mm Yamaha R1 carbs will only cost around $400 and I've got a mate that can make the manifold cheap, so it's not goin to be a big expense compared to computer + itb though. I just don't know how to make the linkage, or even where to go. It's definitely going to happen but it will be the last step. First step will be setting up the ignition with an MSD 6AL, then dropping in a rebuilt 320i head + 2.7 bottom end, then sort out the carbs.
Ohhh, I don't know how to rebuild diffs. A friend works at a diff shop and he is doing a cheap cashy for me. Including pressing in the poly diff mount.M20B23 Euro 323i - The Legend Of Ron Burgundrot
Originally posted by OniKyan View PostNah, not really. I just don't know how to go about making the linkage between the carbs. Two sets of 41mm Yamaha R1 carbs will only cost around $400 and I've got a mate that can make the manifold cheap, so it's not goin to be a big expense compared to computer + itb though. I just don't know how to make the linkage, or even where to go. It's definitely going to happen but it will be the last step. First step will be setting up the ignition with an MSD 6AL, then dropping in a rebuilt 320i head + 2.7 bottom end, then sort out the carbs.
Yeh linkage is a bit of a pain. I have a few ideas but all require some fabbing.sigpic
It should be a lot better than what it is now. The reason I'm doing the ignition first is because it sucks. Half the time I stomp on the loud pedal, spark breaks down at around 4,000RPM and it feels like I'm driving a 2.3 ETA. No fun at all. It's great when it works but 4,500 RPM red lines are very uncool, especially when you just down shifted to overtake a derp.
Not sure if you have seen them but there are actually a few threads online about rebuilding the BMW diffs. Some of them were basically parts lists but there was a really good one where the guy goes into depth and shows you the entire process. When I jump on computer I'll have a look for it.Last edited by OniKyan; 07-17-2012, 01:46 AM.M20B23 Euro 323i - The Legend Of Ron Burgundrot
Originally posted by OniKyanAll the bearings, seals, gaskets, o rings and crush sleeve were around $160 posted, the poly diff mount was $40 posted and my friend is charging $150 to do the rebuild. $350 for a rebuilt diff is not bad.
I could ask my friend if he wants to do another cashy come time for your diff?
Yeh if you mate is keen that would be great. Even if he charges his normal rate and lets me watch would be good just want some first hand experiance with it. Mind you it will be a good 6 months still before I am ready to do a diff.sigpic
So, I bought my first real camera, it's a Pentax K-X with a Pentax-M 50mm f1.7 lens. Still learning how to use the thing since I've only ever had an iPhone as a camera before.
Too many clutch kicks and scandos.
Home made strut brace.
No, I don't really wash my car.
Random intersection.
Still learning to use my camera.
Ron's good side
Ron's ugly side.
Replacement door is primed and waiting for a coat of paint. As soon as that goes on, the rear quarter will be straightened out. It's already had a bit of a bash and is mostly straight now, just needs the door on as a guide to get the lines perfect.Last edited by OniKyan; 06-25-2012, 08:12 AM.M20B23 Euro 323i - The Legend Of Ron Burgundrot
Also did a coolant to throttle body bypass while I had it all apart.
Deleted this
Did this
Deleted the hose that went from the throttle body to air slide valve completely. Cut the thermostat to throttle body hose in half and connected that directly to the air slide valve.M20B23 Euro 323i - The Legend Of Ron Burgundrot
So, I got rear ended by some Uni Student. I was stationary, waiting for a green light and this guy just ran straight into me. Seriously did not even brake at all. The driver was probably texting, checking Face Book, or something equally retarded.
It really doesn't look that bad but the C pillar trim on the right hand side actually popped out and it's sunken right in on the left hand side, so I assume there is more substantial damage than what is visible in that picture.
/End Thread.Last edited by OniKyan; 04-26-2014, 07:33 AM.M20B23 Euro 323i - The Legend Of Ron Burgundrot
^^ That sucks.^^Projects Hartge,Alpina & AC Schnitzer Builds.http://www.r3vlimited.com/board/showthread.php?t=280601
Yeah, this car has been a string of bad luck.
I hit a kangaroo and destroyed the front bumper.
Some douche reversed out of their car park and hit my right rear side, destroyed a bottle cap and broke my mud flap.
Now some other DB rear ends me.
Hopefully once I get my alpine fixed up, I have better luck with that car. Shame it isn't burgundrot though, my favourite motherfucking colour.Last edited by OniKyan; 09-16-2012, 05:53 AM.M20B23 Euro 323i - The Legend Of Ron Burgundrot
