E30 streeter build
  • Podge
    • Nov 2011
    • 164
    #76
    Quick picture of the e30 still in the garage i have to start working on it again ive been to lazy.
    • Podge
      • Nov 2011
      • 164
      #77
      I haven't touched this car for a few day but I really have to get moving on it so as it is now 12am in Australia I am going to write out a list of what I want to get done tommorrow
      re paint black mould on front bar
      Remove and reprint front lip
      Remove and paint side mirrors
      Fit new front swaybar D bushes
      Remove backseat and parcel tray
      Let's see if I get it done :)
      • tcanin00
        • 41
        #78
        [quote=Podge;2973841]All the rear is almost back in along with the disc brake ass end. I just need to find another drive shaft and I'm set !!! In other news this arrived today :)
        Where did you get this, and how much was it?
        • tcanin00
          • 41
          #79
          And congratulations on the progress on your car! I just ordered all of the parts for my new exhaust system and am impatiently waiting for them. I might have trade worked out for an '86 3235i parts car and I'm pretty excited about it because it would give a lot of the parts I need.
          • Coyote_ar
            • Sep 2009
            • 175
            #80
            i got one just like that, i got it from ebay. about 35usd.
            cheers.
            ---E30 320i Hennarot 1984 Sedan---
            • tcanin00
              • 41
              #81
              I'll have to check eBay then! I just order a lot of parts from eBay, so this will be in the next round when I get paid again.
              • Podge
                • Nov 2011
                • 164
                #82
                My one is a b&m one cost $300 AUD probably the same as the $30 eBay one
                • Podge
                  • Nov 2011
                  • 164
                  #83
                  I now have a working horn. Thank you
                  • Podge
                    • Nov 2011
                    • 164
                    #84
                    SO i have a few things to update!
                    1. stripped interiour
                    2. vacumed and scrubbed stripped interiour
                    3.pulled out the wiering for 3 differant decs and 2 alarms thats all shoved up under the dash
                    4.pulled out the old shit amp wiering I have no pics of 3,4 and 5
                    5.re-taped all of the looms inside the car
                    7.painted black rubber on front bar.
                    8.painted mirrors.
                    When i was changing the subframe over i was trying to get the driveshafts off of the diff to make pressing out the diff bush easer and the whole thing just poped out of the diff! the part that bolts onto the driveshaft and then goes into the diff is what had popped out is this a problem or do i just chuck it back in the diff? i have a picture below and circled the bit that i pulled out.
                    • Dj Buttchug
                      • Jun 2010
                      • 7688
                      #85
                      its held in by a retainer clip. just adjust the clip a little and pop it back in. it will be fine as long as it doesnt start leaking
                      Turbo M42 Build Thread :Here
                      Ig:ryno_pzk
                      I like the tuna here.
                      Originally posted by lambo
                      • Podge
                        • Nov 2011
                        • 164
                        #86
                        Ok I'll have to look for this clip!! Will it be on the end or can it fall off?
                        • Dj Buttchug
                          • Jun 2010
                          • 7688
                          #87
                          it cant fall off. its a ring clip that sits in a small groove. it basically keeps the shaft from coming out of the actual diff housing. sometimes the ring clip becomes collapsed allowing the shaft to pop out. take a screwdriver and bend the ring clip out a tiny tiny bit. too much and it will be a bitch to get back in.
                          Ig:ryno_pzk
                          • Podge
                            • Nov 2011
                            • 164
                            #88
                            Thanks for that mate!!!
                            • Podge
                              • Nov 2011
                              • 164
                              #89
                              So what do u do at 3:18 am when you can't sleep?
                              • FunfGan
                                • Jan 2011
                                • 4958
                                #90
                                Go dorifto!
                                Go here be happy!
                                Ratchet Garage e30 V8 build.
