91' 318is S52 Swap "The Beast"
  • craiggroves91
    • Oct 2009
    • 3024
    #301
    Can't believe I've had this car for 7 months already!
    Waiting for my harness to come back from Dave and I'm still waiting for the correct flywheel friction plate to come. Once thats in, I should have everything to mate the trans back up!!!!
    1989 BMW 325i SOLD
    1998 BMW Estoril Blue e36 M3/4/5 SOLD
    1987 BMW 325 (The Piece) SOLD
    1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
    • F34R
      sLaughter
      • 12376
      #302
      Looks great man! I feel bad for you West coast guys and Smog/bar or whatever. Must be a total PITA.
      Instagram: @BWeissLeather
      Current cars:
      ~ '87 325 M30B35 swap
      ~ '87 535
      ~ 01 540 Msport 6spd
      ~ '06 X5 4.8is
      • craiggroves91
        • Oct 2009
        • 3024
        #303
        thanks!
        It sure is a PITA!
        So to run the e34 m50 pan I just remove the s52 windage tray and run the one that is integrated into the m50 pan?
        Also, do you guys know if silicone is needed anywhere on the oil pan gasket? or is it good to go?
        1989 BMW 325i SOLD
        • mtlbloodshot
          • Jul 2011
          • 761
          #304
          Originally posted by cjdontthink
          thanks!
          It sure is a PITA!
          Yes just remove the S52 windage tray. There is kinda U bracket too that needs to come off, just bend it back and forth till it comes off.Make the sure its done with the engine in its normal position.
          Before I installed the oil pan gasket, I put some silicone on the joints both side of timing case cover and some on each corner close to the clutch/flywheel setup...
          MY BUILD THREAD
          http://www.r3vlimited.com/board/showthread.php?t=235231
          INSTAGRAM : @luchcolaneri
          • craiggroves91
            • Oct 2009
            • 3024
            #305
            I appreciate the info man!
            Valuable pictures in that thread
            1989 BMW 325i SOLD
            • Roysneon
              • 4505
              #306
              Looks awesome, this is an S52 swap done right.
              Originally posted by mbonanni
              I am a pursit now.
              • craiggroves91
                • Oct 2009
                • 3024
                #307
                Finally, the last piece of the puzzle needed to drop the engine in has arrived.
                A 20 hole fidanza flywheel friction plate replacement. I had to return a 18 hole one and wait for an exchange. This delayed me quite a bit
                Here is the lightweight fidanza flywheel pictured with the f1 racing stage 2 e34 m5 clutch kit
                1989 BMW 325i SOLD
                • jaywood
                  • Jul 2010
                  • 4528
                  #308
                  Do you have the wiring harness back yet?
                  • craiggroves91
                    • Oct 2009
                    • 3024
                    #309
                    Sure do!!
                    1989 BMW 325i SOLD
                    • freeride53
                      • 11972
                      #310
                      Wow Craig. Backtracking a few pages, my mouth started drooling.
                      Definately a lucky man, and well done on all of the hard work (both being able to coin up and do all the work).
                      Yes, I'm jelly.
                      Sina
                      1983 Peugeot 505 STI
                      1992 Volvo 240 Wagon
                      • craiggroves91
                        • Oct 2009
                        • 3024
                        #311
                        Yes, I'm jelly.
                        Sina
                        Thanks! I really appreciate it.
                        I need all the encouragement I can get.
                        Next free day I have the engine is hopefully going to at least be dropped in the car!
                        1989 BMW 325i SOLD
                        • craiggroves91
                          • Oct 2009
                          • 3024
                          #312
                          Hey guys,
                          I ordered the 6pk1400 and it fits two ways.
                          It fits with the idler pulley like this, but I'm not sure if this is acceptable because the ribs are on the smooth surface of the idler pulley
                          or how lifeiskaos did it in this thread:
                          What would be better?
                          1989 BMW 325i SOLD
                          • sgmira_e30
                            • 89
                            #313
                            You need the smooth part of the belt running on the pulley. The belt is in the right place except it should run below the tensioner pulley running from the water pump to the alternator not above.
                            1989 325i 5Lug S52 - RIP 1991 325i S52
                            • craiggroves91
                              • Oct 2009
                              • 3024
                              #314
                              Yeah, I don't think its possible to run it under the idler pulley.
                              Maybe its best to run it without it then or i can get a belt that is a little bit longer and still use it
                              1989 BMW 325i SOLD
                              • mtlbloodshot
                                • Jul 2011
                                • 761
                                #315
                                Thats my M52.. You're missing your idler pulley.
                                You're deleting your POWER STEERING iirc so if that belt is good for that setup, slap on your idler and you should be alright. The smooth side of the belt must turn the idler.
                                MY BUILD THREAD
