91' 318is S52 Swap "The Beast"
  • Cabriolet
    • 9620
    #286
    nice work man. gratz on getting that good engine.
    Much wow
    I hate 4 doors
    • jaywood
      • Jul 2010
      • 4528
      #287
      Originally posted by cjdontthink
      Whats smog?
      • craiggroves91
        • Oct 2009
        • 3024
        #288
        Originally posted by jaywood
        Just a little tired of being asked, its cool though.
        For the moment, I'm just going to get it running. Whether its to BAR's expectations or not.
        I'll get it smogged and then maybe worry about BAR later
        1989 BMW 325i SOLD
        1998 BMW Estoril Blue e36 M3/4/5 SOLD
        1987 BMW 325 (The Piece) SOLD
        1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
        • jaywood
          • Jul 2010
          • 4528
          #289
          Probably should have read through the thread to see if it was already asked...my bad.
          Good luck on the swap! Take lots of pics for us. Are you doing the wiring yourself?
          • craiggroves91
            • Oct 2009
            • 3024
            #290
            No biggy man!
            There will be lots of pictures, dont worry.
            I plan on having Dave from markertmotorwerks reworking the harness
            1989 BMW 325i SOLD
            • craiggroves91
              • Oct 2009
              • 3024
              #291
              Pulled this thing from pick n pull
              Gave the s52 a bath
              Masked off for painting the block
              After a couple coats
              Intake side
              Couple coats
              Finished product
              Intake side
              Lots of goods came
              This thing was a pretty penny
              Painted exhaust manifolds with welded flanges for the smog garbage
              Exhaust side with mount arm back on and freshly painted manifolds w/ new gaskets
              Clean
              Oil filter housing on with new gasket
              New oil filter kit
              New Stewart high performance water pump,Thermostat, housing gasket. Alternator back on
              1989 BMW 325i SOLD
              • craiggroves91
                • Oct 2009
                • 3024
                #292
                Took the valve cover off to do the Valve cover gasket
                Valve cover gasket all done
                Slammed the s52 injectors into the m50 fuel rail and manifold
                Got my ECU back from tuning
                I think I have everything but a driveshaft and m3 selector rod.
                Yesterday I sent off my wiring harness to Dave @ markertmotorworks for modification.
                Ordered a clutch kit and flywheel plate so I can get the trans bolted back up after I do the rear main seal
                1989 BMW 325i SOLD
                • Cabriolet
                  • 9620
                  #293
                  Nice progress Craig!
                  Much wow
                  I hate 4 doors
                  • theBAYsics
                    • May 2011
                    • 115
                    #294
                    lookin good craig! i wanna check this out when youre done.
                    • craiggroves91
                      • Oct 2009
                      • 3024
                      #295
                      Thanks!
                      You can definitely check it out!
                      Just waiting for parts at the moment!
                      1989 BMW 325i SOLD
                      • Alberthype
                        • May 2011
                        • 132
                        #296
                        how's the piece ?
                        • Vivek
                          attention whore/retard/bitch
                          • 6167
                          #297
                          Definitely wanna come see this sometime
                          1992 Mauritiusblau Vert
                          2011 Alpinweiss 335is coupe
                          2002 540i/6 Black/Black
                          2003 GSX-R 750 (RIP)
                          • craiggroves91
                            • Oct 2009
                            • 3024
                            #298
                            Originally posted by Alberthype
                            how's the piece ?
                            Still down :(((
                            1989 BMW 325i SOLD
                            • craiggroves91
                              • Oct 2009
                              • 3024
                              #299
                              Hopefully youll see it running! haha
                              1989 BMW 325i SOLD
                              • craiggroves91
                                • Oct 2009
                                • 3024
                                #300
                                Hot tanked my oil pan. Came out pretty clean!
                                Waiting on the pickup tube gasket to come, then I can put the pan on!
                                Oil pump nut drilled for safety wire, so it doesn't back off
                                Also got the m50 manifold conversion kit from m50manifold.com. Comes with new intake mani and a new specialized throttle body gasket
                                1989 BMW 325i SOLD
