Looking good! Slam that thing ;)
My Very Own V8 Vert (First drive vid added)
I missed this thread.
Hows the wheel bearings going? heheComment
Thanks everyone!
More pics coming up.
glucklich, I still hate you. I haven't done it yet but I shall soon. I'm thinking the entire right side was sitting in high water because the the brakes are dragging as well. Brand new pad worn to the metal but only on the front passenger and on one pad.
Nice find. What part of Houston you live in?EuropeanAG.com - Owner/Founder
CamberWears.com - Co-Founder
1978 VW Rabbit - SOLD
1991 BMW 325iC - 3 year project (year 2)
1992 VW Cabriolet - Wife's Project
1998 VW Jetta Wolfsburg - SOLD
2006 Audi A3 Sportswagon - SOLD
2007 Toyota Tundra - (my daily)
2009 Ford Flex - Baby mobile - Traded
2013 Volkswagen CC Sport - (wife's DD)
-"A little bit awesomely"Comment
No, the warning applies to manuals too. The concern is that while in neutral the gearsets aren't moving at the normal rotational speed so the transmission fluid doesn't get distributed fully to the far reaching ends of the tailshaft and bearing.
Recommendation is if you're towing it over 50 miles you need to disconnect the driveshaft.Das ist nicht nur nicht richtig, es ist nicht einmal falsch!Comment
I just consulted my '92 318ic owner's manual and I'm afraid you're misinformed. The restriction is for automatics only and the max. distance is 30 miles (which can be safely exceeded if you add an extra quart of ATF or remove the driveshaft).No, the warning applies to manuals too. The concern is that while in neutral the gearsets aren't moving at the normal rotational speed so the transmission fluid doesn't get distributed fully to the far reaching ends of the tailshaft and bearing.
Recommendation is if you're towing it over 50 miles you need to disconnect the driveshaft.Comment
So as the time goes by......
So the car came with a blown M42. After three hours and a tall Shiner, the problem was resolved.
I got the M42 pretty quiet. Had to swap the cams and the lifters. The lifters were like rock solid. Timing chain still makes noise even with new guides all over.
Check the pics.
This is what an M42 looks like when you slap all 4 cylinders with valves and leave it sitting with the head off.
Has a pretty new flywheel and new BMW clutch
Inteeria shots
Shampoo doesn't really work on 20yr old carpet
Everyone should get this stereo. It does everything and matches. I'll do a write up on using the factory amp as well
The old dirty bastard
Cleaning the shooters
Adapters
I also took the opportunity to zip in my new rear window.
Took all of 15 minutes. Blurry cell shot.
I like this car!
After a clay bar, compound, and buff/wax
Right now I still don't know if I'd like to keep the m42. I like the mileage but that's it.
In the works is a set of euro grilles, lights, is lip, spoiler, and tires for the shooters.
nice, looks really clean over all. I say m50 swap/coilovers(street rates)~ Puch Cafe. ~ Do business? feedback ~ Check out my leather company ~
Instagram: @BWeissLeather
Current cars:
~ '87 325 M30B35 swap
~ '87 535
~ 01 540 Msport 6spd
~ '06 X5 4.8isComment
