FORGED FULLY 🐬 grey S50,shaved, KW, brembos, garret g30/770 fr&rear 5 lug,
Those wheels look awesome on the mini..The first car I ever rode in was an e30
1992 Mauritiusblau Vert
2011 Alpinweiss 335is coupe
2002 540i/6 Black/Black
2003 GSX-R 750 (RIP)Comment
2010 turbo charged , dont know anything about it but its the guy i bought my e30 froms daily driver. he use to work for mini , those are all bbs wheels he decided to do what i was going to do , he also owns a e30 2jz swap i have yet to see the car in person but my this guy has 11 cars thats why i got mine so cheap , but he thinks he can run 9 second qaurters if he can keep the tire on the track
i sanded the journals on the crank shaft with 600 grit
and i actually used the same piston rings i just cleaned the oil ring and spun them to clean inside the grooves really well i spent like 2 hours per piston maybe longer
i used scotch bright and a pick and simple green
dont get the pistons wet with water
i put all new main bearings and rod bearings and rod bolts , re used the main bolts
what about the crankshaft did you lighten it or do something to it?i sanded the journals on the crank shaft with 600 grit
i put all new main bearings and rod bearings and rod bolts , re used the main boltsComment
So I was Drivig my car this morning and all of a sudden my car died,
I tried to start it up it started for like 0 point 2 and then she died again
So first thought that I had no fuel or Somthing because my fuel sender doesn't work ,
My pump had been loud latley because I ran it till it was dry the other day
Used a test light and Appernttly I'm gettin power so that's a pic of me towing my car out with just some rope
im going to buy a walbro 255 pump to see if it fixes the issue
my last pump i bought , was purchased at a junkyardLast edited by e30m20TurbO7; 10-03-2012, 06:13 AM.Comment
Yea I know my grammar sucks Because I wrote this entire thread on my iPhone if that counts for anything , and i just made that name for the thread today and I haven't edited it ever , but I will rewrite this thread when I have time in the future. I'm a 90's child , lets just say that at the least.
I decided to buff my peeling clear coat came out nice.
